![]() Join Date: Jul 2007
Trader Rating: (106)
Misc s13 parts, CHEAP...
S-13 powersteering hardline assembly
This is the power steering hardline assembly from a DOHC (kade) s13 240sx. It is the complete assembly including all brackets and clips and both hardlines only. I do not have the rubber hose section or the pressure switch unfortuanetly. Those can be sourced new at your local auto parts store or used here of course. The lines and brackets are in good shape no damage at all as far as I can tell. $30 OBO Chuki bumper grilles The grilles are in pretty good shape, nothing but minor knicks. The screws are included with the grilles, but unfortuanetly I don't have the screw clips. $15 S-13 pop-up light shrouds The shrouds are not in perfect condition, they do have some large scuffs on them. They are not cracked though and fit and function perfectly. $10 Cheap s13 steering wheel hub This is a no-name brand hub. Unfortuanetly I do not have the plastic cover for it. Also the wire for the horn is broken off. It is otherwise completely functional and the turn signal works properly. $5 S-13 radio brackets w/beat up din pocket The radio brackets are in good shape and the din pocket is useable, it's just not that pretty. The main reason that I'm even including it is because it keeps the screws from getting lost. Unfortuanetly I do not have the special screws for the radio though... $10 S-13 ignition lock with key The lock cylinder is fully functional and is off an s-13. The key for the lock is also included. SOLD! S-13 sidemarker lights This is a full set of clean sidemarker lights for an s13. The harnesses and bulbs are included... ONLY the passenger's side front light is left, all others SOLD! $5 each light Last edited by racepar1; 11-14-2010 at 09:28 PM.. |
It's already paid for, sorry...
Thanks man, I'll get you a tracking # ASAP... |
