RB26 Kouki Race Car
!!!!!SOLD!!!!!
Here are the specs: Chassis: 1997 Nissan 240sx SE Horsepower/Torque: 606rwhp @8000RPM 466rwtq @6446RPM @ 22psi (want more power? Just turn up the boost! We felt 600 was balanced) Weight: 3030lbs With driver and Full Tank Engine: R32 rb26dett Jun crank collar Tomei oil restrictor Tomei oil pan baffle Greddy oil pump Greddy clear timing belt cover Greddy intake manifold HKS 272 in/ex cams HKS adjustible cam gears HKS timing belt HKS fuel rail Wiseco 86.5mm pistons Eagle H beam rods Cometic head gasket ACL Race rod bearings ACL Race main bearings ARP head studs ARP main studs Twin Garrett gt2871r-10's TSI Ported OEM exhaust manifolds TSI Ported ITB runners TSI -3an SS braided turbo oil and water lines TSI Divided OEM twin turbo pipe TSI Ported and polished head TSI Custom intake pipes TSI -6an SS braided power steering lines and power steering cooler TSI -10an SS braided oil filter relocation kit and oil cooler kit using Greddy thermostatic filter relocator ATI race crank damper and water pump pulley Dual synapse blow off valves Aem air filters Mckinney Motorsports touge downpipe Mckinney Motorsports fmic kit NGK bkr7e spark plugs Isis Performance blast pipe exhaust with 4" tips FabWorks custom oil catch can FabWorks -AN valve cover adaptors Cooling: Koyo aluminum radiator Flex-a-lite 340 series dual electric pusher fans Raw Brokerage radiator hoses N1 OEM water pump Nismo thermostat NRG radiator diversion panel DIF PWM fan controller Fuel: Injector Dynamics ID1000 injectors Dual Aeromotive 340lph intank fuel pumps Aeromotive FPR Powerhouse Racing billet fuel hat TSI fuel pump direct-wire relay kit TSI -8an feed lines with inline fuel filter & -6an return lines Drivetrain: Rb25det transmission Spec Super Twin clutch Isis Performance Short shifter Mckinney Motorsports engine and transmission mounts with solid isolators Driveshaft Shop 4.5" aluminum "1000hp" driveshaft S15 helical differential Suspension: Fortune Auto 510 Series coilovers with Swift Springs upgrade 12k front /10k rear Fortune Auto tension rods Fortune Auto ruca’s Fortune Auto traction arms Fortune Auto toe arms Stance solid Subframe bushings Stance solid Differential bushings SPL Eccentric lockout kit Sikky 32mm front sway bar Oem rear sway bar Brakes: Z32 front calipers Z32 rear calipers Z32 rear e-brake assembly R33 e-brake cables Carbotech xp20 front pads Carbotech xp10 rear pads Powerslot rotors Exterior: Shine Auto front bumper Shine Auto side skirts Shine Auto rear valences Shine Auto carbon fiber rear diffuser OEM JDM s14 kouki rear bumper OEM 180sx type-x turn signals B-Magic 30mm front fenders widened even more Origin type2 50mm rear over fenders Seibon vented carbon fiber hood Kognition chassis mount 72" wing Euro spec oem kouki headlights Sonar l.e.d. tail lights Nagisa Auto GT front tow hook TSI Custom Rear tow hook Interior: Bride zeta3 xl seat Bride zeta3 xl seat slider/bracket Nrg short hub Nrg 2.5 quick release Nardi 360mm deep corn steering wheel Nismo Shift Knob Battery relocation kit Firecharger dual nozzle fire suppression system Rjs racing harness Rjs racing window net Custom 8point D.O.M. rollcage with "Nascar" door bars Electronics: AEM v2 ems Racepak iq3 digital dash with AEM interface Dual AEM uego wideband gauges AEM serial datastream gauge Stri oil temperature gauge Stri oil pressure gauge Stri water temperature gauge Hotlap v2 laptimer Wheels/Tires: XXR 527 17x9.75 +25 wheels Nitto nt01 275/40/17 tires Project kics r40 neo chrome lug nuts Project kics 10mm spacers all around Nismo 60mm Extended Wheel Studs Pictures: More Pictures can be found HERE Last edited by sileight_04; 02-27-2013 at 10:59 PM.. Reason: Sold |
#2 | |
![]() Join Date: Nov 2011
Nice build.
Im sure people will complain about XXRs though
Thanks! Maybe so but we chose these due to them being easily replaceable. We've bent Volks and Eneki's on other race cars.
The colors mesh well. Thanks!! As are we. ![]() Thanks, it sure does! my starting price is 1/3 of whats been put into it. Thanks! I need to move this and am extremely flexible. Throw some offers my way people. |
Since I've been getting lots of interest in the car and trailer separately and I need to sell this soon. I will list separate pricing and my final price drop.
Car only: $22K obo Trailer only: $5k obo |
![]() Join Date: Sep 2009
if intewrested in trades let me know. i have a 2004 350z fresh ls6 swap. needs minor work but runs and drives.needs a map tune pm me or text at 2173902736
![]() Join Date: Jan 2011
Perfect for someone wanting a to go Pro level!! Awesome looking car at an even more awesome Price. Alot of money invested in this im sher of it! GLWS
#17 | ||
Thanks everyone!!! and thank you for all of the offers, lets get this sold. |
#19 |
![]() Join Date: Mar 2008
Wow this car is FUCKING gorgeous! seriously man. I have to say that this thing is built right!
If I had the money I would def of purchased this from you.. |
#26 |
Here are a couple videos
Dyno Video https://www.youtube.com/watch?v=CH0MUU-fXow A customers video walkaround https://www.youtube.com/watch?v=Z_GWBPojk2o |
| drift, kouki, race, rb26, s14 |
