S14 push start button/ignition wiring
Posting here for the 1st time
![]() Bought and installed an alarm/keyless entry kit with remote/push start button features (amazon easyguard ec003). Wiring for keyless entry part is pretty straight forward and got it working. But confused with ignition wiring for push start button. After a few trials and errors, it got to a point where it cranks up but wont turn over. Yes ive searched but there must be different versions of ignition with different color codes out there. Please help me identify the starter wire, ignition 1 and 2, ACC and constant 12v on my ignition. ![]() ![]() |
![]() Join Date: Jun 2003
Trader Rating: (129)
cranking and turning over are the same thing. the starter is physically engaging with the flywheel, and making the pistons go up and down. this IS turning over.
WHY are you installing a pushbutton when the factory key and ignition switch work just fine? the FSM wiring diagrams do a great job of showing which wires are the ones you're looking for. |
#3 | |
I will do more searches but if anyone knows how to wire these up correctly please lmk.. thanks |
![]() Join Date: May 2019
https://imgur.com/TTQtfu4
https://imgur.com/TTQtfu4 https://imgur.com/j6ZWx9l Downlaod the fsm for ur car. Electrical diagram is very easy to follow Also get a multimeter, u can ohm test each wire cycle the key to see what wire gets power at what point |
