![]() Join Date: May 2008
car dies when put in neutral
Hey guys i've been experiencing some problems on my blacktop sr20det. Couple nights ago im about to approach a stop light so i put it in nuetral while its rolling to the light my car dies on me so i start it right back up and drives normal. Other thing is when i put i cruise and put the car in nuetral the rpm drops below 500rpm stutters like its wants to die out then it will go back up to 1000rpm. Any one know whats going on with it?
Thanks Jimmy |
![]() Join Date: Dec 2006
Probably need a tune up
When was the last time you changed your plugs? Clean the MAF and AICV, Make sure ECU is Grounded. throw in some Fuel Injector Cleaner. And check for Vacuum leaks
Is this just recently that it's been happening? Do you happen to have a BOV that's being vented to the atmosphere? Just wondering because it's pretty common for the SR's to act like that with a BOV. Just gotta change your driving style a bit to help keep the RPMs from dropping below 500.
I got the spark plugs re-placed 1 month ago when i swapped the motor in but i still have to check all the ecu etc... And yes i do have a HKS SSQV BOV thats vented to the atmosphere
