Old 08-15-2014, 07:55 PM   #1
Empire087
Empire087 is an unknown quantity at this point
Rb20det silver top idleing rough at cold and hard to start
So ive been slowly getting my rb running a little better every day. So heres the breakdown:
Car will start, but it takes gas to get it to start when cold. It will turn over and turn over and try and start a few times. Battery is brand new 800cca.
-Car once started will run rough, and it may die. However if it idles for more than 10 seconds or so it will usually stay running.
-Car will make it all the way to warm and idle up.
-if i where to shut it off i may have to apply gas to start it again.
-for whatever reason my stock tach wont even work, and my aftermarket tach wont work. I even wired in a 10k resistor. Not sure why.
I replaced the coolant temp sensor made no difference, pretty sure i wired everything correctly. If anyone can give me a hand id greatly appreciate it!
Thanks,
Dakota
Empire087 is offline   Reply With Quote
Old 08-15-2014, 08:01 PM   #2
Sileighty_85
Sileighty_85's Avatar
Dirty/Bad MAFS, Boost or Vac leaks, Old/Bad spark plugs.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-16-2014, 06:21 PM   #3
Empire087
Thanks so much on those!!!! replaced the spark plugs and cleaned the maf and it fired to life like right away, despite not having the maf hooked up lol. I was leaning towards spark plugs before but you confirmed it for me.
Again thanks a ton!
Old 08-16-2014, 07:19 PM   #4
Sileighty_85
Again thanks a ton!
Nice, No prob.
just make sure you gap the plugs properly, (they are not pre gaped)
Cant remember for RB20, so search around and see what ppl gap theirs to.
後輪駆動車1番
1986 SR86 - 200ish
Old 08-16-2014, 08:50 PM   #5
Empire087
Im running a bkr7e, which im pretty sure came pre gapped at .032. I double checked all of them and made sure they where the same. I figure so long as it doesnt blow out under boost ill call it good. If not ill just re gap them to what everyone runs those plugs at .028.
