Old 05-17-2011, 01:04 PM   #2731
maverickmotorsports
maverickmotorsports is an unknown quantity at this point
Maybe you guys could help me with this.
ONLY mod is PBM tie rod spacers.
Why doesn't my passenger side get the badass angle that my drivers side does?
When drifting at full right lock the passenger wheel will sometimes go over center to where the tie rod hits the bump stop, and then I have a bitch of a time pulling out of it.
However when at full left lock, the tie rod is already on the bump stop with way more angle, and I can pull out of it just fine every time...
Thinking about getting George's passenger side rack extension and re centering, would that fix it?
Try re-centering the steering rack. My guess is that is the problem right there. You're getting to the point where you have enough angle with the stock knuckles to start over-centering. I'd suggest looking at modified knuckles if you start needing more angle.
-George Marstanovic
Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more!
http://www.maverick-motorsports.com/collections/all
maverickmotorsports is offline   Reply With Quote
Old 05-18-2011, 01:19 AM   #2732
az_240
az_240's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
YouTube - Matt Powers Crash
^here's a vid of the matt powers dirt drop for anyone interested.
Old 05-18-2011, 05:51 PM   #2733
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
Feedback Score: 82 reviews
sick angle!
NEED Bolt kits for your car?
Old 05-20-2011, 09:25 AM   #2734
VIPDRFT
VIPDRFT's Avatar
VIPDRFT has a spectacular aura aboutVIPDRFT has a spectacular aura aboutVIPDRFT has a spectacular aura aboutVIPDRFT has a spectacular aura aboutVIPDRFT has a spectacular aura aboutVIPDRFT has a spectacular aura about
Originally Posted by ballinnmiami240sx View Post
How was this accomplished? Inside wheels has more angle than the outside wheel. I have made knuckles before but this is just rediculous. I think he has the best "drift" set up right now. Backwards entries like a boss.
Drunk talk..sorry!!!
I would love to see the front suspension set up on the team burst car. He definetly runs an odd setup on the s-chassy. just look at his car at a stand still. Front end pretty high, rear down.......hummm. The only other person with a set up like this is DAI, and he is killing it.
Also, what happen to matt?
I have an issue of Drift Tengoku with an article about different drivers' knuckle setup. Nakamura's is featured and it has a pretty good shot of his front suspension. I'll see if I can scan and post it.
Holding it and...WHEEL POPS OFF! O^O^O
VIPDRFT is offline   Reply With Quote
Old 05-20-2011, 09:35 AM   #2735
PoorMans180SX
PoorMans180SX's Avatar
Someone cut my control arms in half!
Old 05-20-2011, 12:35 PM   #2736
conrad_s13.5
conrad_s13.5's Avatar
^bout time
cONtRol FReAkS
Old 05-21-2011, 05:32 PM   #2737
godrifttoday
Trader Rating: (82)
U must have failed math... Lol just messing.. Why did u cut the lower control arms? What will u be doing
Old 05-21-2011, 06:42 PM   #2738
DC Dan MAX USA
DC Dan MAX USA's Avatar
Trader Rating: (79)
DC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond repute
Feedback Score: 79 reviews
Thought I'd throw up a little teaser on the PSM lower control arms. I'll let Dan Chime in with the info if he wants.
The one on the left is going on the inside of the FLCA, the one on the right is going to be used in their other multi-link parts. They are machined from billet.
I see you have been lurking on my site = )
Correct the LCA type adjuster will have to be adjusted with the rod end unbolted from the car to bring the LCA ultimate strength. Other arms will get the double adjuster that lets you change the length on the vehicle.
Yes the prototypes were machined from billet. That process really takes almost impossible amounts of time and money and for production parts we have invested in forging dies for all of these parts. I hope you guys can appreciate this process & what we are putting into the 2011 parts line up and understand why we are taking our time on the release. I know you guys have been frustrated.
These are like the clamping rod ends you would see on custom pro off road rigs & trophy trucks. Only the companies that sell that stuff for the off road guys use sand casted steel parts. Our production parts will be forged with a 100% CNC machined finish. This clamping design was implemented because they don't come loose. Now I dont go around telling people that our stuff is the best, I let them make their own educated decisions on what to buy...
But this time around I really have to say, the 2011 Parts Shop MAX multilink will be the best, strongest, highest quality, and most stylish parts available. Not just the market for 240sx, we are really exceeding the standards of any parts I have have seen for any vehicle.
This standard carries on into the forged clamping nuts and CrMo one piece taper rods we have developed as well (not pictured).
You can see that we have added quite a bit of thread overlap and range of adjustability to the new parts as well as increasing the surface area of the bearing side spacer.
Thanks for your patience and support, we should have some more interesting announcements coming soon regarding the MAX 2011 multilink.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate.
Order Inquiry: IM me your real name and paypal address.
Thanks for your business!
DC Dan MAX USA is offline   Reply With Quote
Old 05-21-2011, 08:56 PM   #2739
Razi
Razi is an unknown quantity at this point
I love you guys!
Razi is offline   Reply With Quote
Old 05-22-2011, 05:59 PM   #2740
IsBettyBish
IsBettyBish is an unknown quantity at this point
^^ hurry with the parts and more details.
IsBettyBish is offline   Reply With Quote
Old 05-22-2011, 06:07 PM   #2741
Def
Is there a reason you guys don't use off the shelf rod ends?
DEFSPORT
Old 05-22-2011, 08:21 PM   #2742
PoorMans180SX
Found some more pics of Nakamura's S13, and it clearly retains some ackerman, as seen here:
Hahaha, good one.
I'll be extending them 10 or 15mm. Adding negative camber with the LCA's means I will be able to adjust my caster by flipping my camber plates. I'll be doing some testing that's for sure. Cutting and extending them outside the tension rod mount points also gives me a little more clearance for more angle.
Old 05-23-2011, 10:31 AM   #2743
PoorMans180SX
Haha yeah, I'm JankiS13 on there, I started that thread
Looking forward to more updates!
Old 05-23-2011, 01:15 PM   #2744
PoorMans180SX
Just found this Drift Tengoku scan of a knuckle comparison article. Maybe someone can find a better version and someone to translate? I'm wondering what the sweep graphs are...
Aftermarket s13 knuckles - Hardtuned.net
Old 05-23-2011, 01:55 PM   #2745
SicBastard
SicBastard's Avatar
Lookin at all these modified knuckles has me wondering...
has anybody ever spaced the entire bottom of the knuckle down for roll center correction?
BURN OUT IN YOUR FACE!
#/f/tech-talk/147301...d-gto-pan.html
Old 05-23-2011, 02:30 PM   #2746
PoorMans180SX
Like this?
Or this?
Yeah, I plan on it once I get these angle mods done and tested.
Old 05-23-2011, 02:50 PM   #2747
DC Dan MAX USA
Trader Rating: (79)
The direction we are going brings more range of adjustment and its less expensive to replace the bearing than to replace a rod end in the future.
No one makes anything exactly like it. The use of forged materials throughout, the one piece integration of the clamps (this is really hard to make), the unique dust covers and side spacers, its all just us doing things our own way trying to be thoughtful about adding the best features you cant find anywhere else.
Old 05-23-2011, 04:26 PM   #2748
SicBastard
SicBastard's Avatar
Poorman that's totally sweet! Thanx for the pix.
DC Dan what kind of replacement cost range will the bearings be? Will you reccomend a bearing change interval? I'm loving the PBM new parts, keep it up!
Old 05-23-2011, 04:45 PM   #2749
dsastr_clan
dsastr_clan is an unknown quantity at this point
can i anybody give me some tips on how to re center my steering rack? i feel that when i turn to the left i had to pull harder than when i do to the right
dsastr_clan is offline   Reply With Quote
Old 05-23-2011, 05:10 PM   #2750
95KA-Turbo
95KA-Turbo's Avatar
Like this?
http://i24.photobucket.com/albums/c2...1/DSC00997.jpg
Or this?
[]http://www.prmsg.org/albums/album126/Drop_spindles_03.sized.jpg[/]
[]http://i582.photobucket.com/albums/ss263/logrmyk/IMG_03201.jpg[/]
Any info on what they're doing in that top picture? Just boxing it in with super thick steel, or is it solid steel that's threaded?
Instagram - SJKnoop
Old 05-23-2011, 05:26 PM   #2751
PoorMans180SX
Solid steel. That bolt is just to align it for welding.
Old 05-23-2011, 08:21 PM   #2752
McCoy
McCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of light
Looks familiar... wonder who these belong too
McCoy is offline   Reply With Quote
Old 05-23-2011, 09:46 PM   #2753
GripTerror
GripTerror is an unknown quantity at this point
uh mr mccoy?
GripTerror is offline   Reply With Quote
Old 05-23-2011, 11:23 PM   #2754
95KA-Turbo
95KA-Turbo's Avatar
Holy shit, what's that add like 12lbs of unsprung weight???
Instagram - SJKnoop
Old 05-24-2011, 05:48 AM   #2755
PoorMans180SX
Hahaha, probably more like a pound.
Old 05-24-2011, 07:47 AM   #2756
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Originally Posted by GripTerror View Post
uh mr mccoy?
more like mr copy and paste.
Old 05-24-2011, 08:15 AM   #2757
McCoy
OK Mr wise guy... I'll add a few.
Before and after of the LCA with the above spindles.
Old 05-24-2011, 12:32 PM   #2758
GripTerror
thats looks hot, the slicks make it that much more sexy too
Old 05-24-2011, 01:25 PM   #2759
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
While I appreciate what you're doing, are you guys doing any actual R+D or stress analysis when it comes to your 'own' bearing setup?
I hate to sound like a doubter, but with their already being companies in existence that create/manufacture Rod ends that are PLENTY strong, I really don't see the cost savings and or 'business' perspective beyond doing it all yourself other than to create a product that is totally one off just 'because'.
I have nothing against making exclusive repair and or replacement parts, but if there is anything I can assure you, it's that in our business (truck repair) there is nothing more frustrating than dealing with some companies who design things to be different just because they can(Mack for example)
Old 05-24-2011, 02:33 PM   #2760
GSXRJJordan
GSXRJJordan's Avatar
Everything I've seen from PSM has been engineered from the racer's perspective (give them what they want, built it big enough until it doesn't break) and I've never seen/heard of their joints breaking. Great rod ends are extremely pricey, good (enough) rod ends can be made for pennies on the dollar. The LCA ball joints are the only thing I can think of that would be really stressed, and need to be a truly high quality part.
