Smoke coming out of spark plug hole!!!
So I was working on my because it wouldnt start and as soon as I removed the third spark plug smoke started coming out. Does it mean the fuel injecter is seized?
![]() Join Date: Apr 2008
Trader Rating: (44)
![]() Feedback Score: 44 reviews
you probably have a blown spark plug gasket..oil might be getting in to your piston from the gasket and then being burned, thus causing smoke..thats what i think.
![]() Join Date: Nov 2009
Trader Rating: (42)
![]() Feedback Score: 42 reviews
lots of confusion in here.....so you tried starting it with the plug out? or what? smoke just doesn't come out of a hole when it's not started.
SW Fab |
![]() Join Date: May 2009
Trader Rating: (31)
![]() Feedback Score: 31 reviews
i know what it is kid... the wiring harness for your ignition coil is fucked!!! you need to zip tie it to your aem intake tube!
VISIT OUR NEW SITE! streetfaction.net |
![]() Feedback Score: 20 reviews
if a injector was seized the only thing to make anything really come out of the hole would be blow by from the piston rings..
replace your plugs because its cheap and easy do a compression test because its cheap and easy. check your injector because its free. there are a few ways to do this ohm test full the whole rail and crank it a bit lisin and see if its clicking switch it out for another one ect.. do that and get back to us with something logical. |
