Lexus Gs300 Track/Drift Rolling Shell. Caged & Suspension
1999 Lexus Gs300 (CLEAN TITLE) with pink in hand
Chassis is track ready for any type of engine of your choosing and it is ready to go, Car handles amazing with the full cage and suspension. It's already manual swapped. Every part that i listed below will be included. Probably some stuffs not listed, but my loss is your gain. 3in one piece Aluminum Driveshaft for 1jz/2jz R154 with Aluminum differential adapter- $700 Welded Rear differential with a 1/2 in plate- $200 Aluminum Radiator/Samco Hoses for 2JZ-GE - $200 Dual Flex a Lite Fans - $200 A/c lines and Condensor - $100 Aeromotive Fuel Pump 340lph - $200 Custom -an fitting stainless lines for the Fuel feed and fuel return -$60 Drift motion -6AN in line Fuel filter - $20 Custom aluminum power steering reservoir -6AN return -10AN feed - $100 -6AN stainless steel lines for the steering rack both return and feed - $80 Suspension: All suspension parts Under 3000 miles Powerd by max coil overs 22kg 20kg - $800 40mm front RCA - $120 New inner and outer tie rods - $60 New lower ball joints - $60 Top speed front under brace -$ 180 SPC front upper control arms - $400 Front and rear blue TRD stabilizer bar - $500 Battle version Aluminum steering rack bushing - $60 Battle version rear upper control arms (Track version) - $600 Battle version rear toe arms -$200 Battle version rear traction arm - $200 Battle version solid differential bushings - $120 Interior: Full custom 6 point weld-in cage - $2500 NRG short hub -$80 NRG quick release - $80 Momo 350mm deep corn leather - $140 ASD hydraulic e brake & custom lines - $320 Joe's Racing rear view mirror - $60 1100watt CRUNCH amp - $60 1000watt Kicker 12in sub - $60 Battery relocated to trunk -$40 Exterior: Authentic BN sports full body kit - $2400 OEM Toyota window visors - $200 OEM Toyota chrome door handles - $250 Depo LED taillights - $300 Serial nine rear quarter panels - $500 Custom hibino style fenders - $350 Toyota aristo Front grille - $100 Custom purple amethyst pearl with gold flakes- $2500 Brakes: - $1500 Front- (under 500 miles) Stoptech rotors Rear- (under 500 miles) Wilwood 4 piston BBK Wilwood 324mm rotors Wilwood brake pads Wilwood stainless steel lines
"if sparks don't fly your rides to high"
#6 | |
im Asking $8500 firm for everything Dudes taking me to court. so i'm just waiting on that.
Final Price.... $8000 FIRM Takes it
if i can't sell it. im going to just throw in another JZ and track it. People sleeping on such a great deal for everything zZzZz
$8000 FIRM Takes it
![]() Join Date: Mar 2014
Damn that sucks! Never buy a built block IMO, hopefully @Slide_Ways14 owns up to selling you a dud basically. I don't know how you could sell someone a block in that condition, I couldn't because I actually care about my seller reputation.
| 2jz, aristo, drift, gs300, track |
