Old 01-24-2010, 01:28 PM   #1
Mr. Phonso
Mr. Phonso is an unknown quantity at this point
fmic cold pipe question
I know its possible to run the cold pipe around the frame rail like in this greddy kit http://www.greddy.com/img/PHP/products/pdf/768.pdf
The main goal is to keep the battery in the same place with no interference.
My question is, is there any ebay kits that sell piping like this?? or if there are any board members that would happen to have this for sale?? I plan to use this with a CX inter cooler core.
Application is S13SR
Mr. Phonso is offline   Reply With Quote
Old 01-24-2010, 02:56 PM   #2
D.Adams
D.Adams's Avatar
well i got a slim bosch batterie and mounted it in the same spot as the oem
like this
“About the time we think we can make ends meet, somebody moves the ends.” ―Herbert Hoover
The build
Owner of NVS Fabrications
Old 01-24-2010, 02:57 PM   #3
Mr. Phonso
yea, thats what im probably going to have to do. 3" hole cutter should do.
cheers.
Old 01-24-2010, 02:58 PM   #4
Mr. Phonso
OH and one more question. I shouldnt have to cut a hole for the hot side, do I? There is already oem hole there for the stock airbox.
Old 01-24-2010, 02:59 PM   #5
D.Adams
D.Adams's Avatar
cheers.
i would go with a 4'' hole. the cold pipe moves and you dont want it to rub on the batterie tray.
The build
Old 01-25-2010, 01:31 PM   #6
Max_PSi
Max_PSi's Avatar
Max_PSi will become famous soon enoughMax_PSi will become famous soon enoughMax_PSi will become famous soon enough
No you shouldn't have to cut anything.
Max_PSi is offline   Reply With Quote
