![]() Join Date: Dec 2013
gauge cluster question
If I found my answer searching I wouldnt be asking here so here it is
Its a 90 s13 with s14 sr20 euro spec Tach does not work connected to ecu tach output i just swaped in dohc cluster and nothing luckly I have autometer tach adapter and works fine. Why wouldn't it work connected to ecu Other thing is trip/odo not working I just put in a s13 speed sensor speedo works but no trip or odometer movement any ideas broken cluster? And speedo is showing about 5mph slower than my gps even my wifes 07 corolla is 3 mph off not too worried about that |
![]() Join Date: Feb 2012
Trader Rating: (37)
Correct your grammar and people might be able to understand you better.
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple |
Trader Rating: (37)
No problem brother.
Not really stuck up. After trying to read your...whatchamacallit, 3x, I said, "the hell w/ trying to make sense of this". I was not trying to give you an English lesson. I clearly pointed out that if YOU made the attempt to correct your grammar, people might chime in w/ some information. Not too many people want to decipher stupidity and laziness, (no offense). But, if you would like, I can possible point you in the right direction to Rosetta Stone, (they have a special going on right now) and they can help you w/ your Engrish wessions. And grammar.
