| South Western States Arizona, California, Hawaii, and Nevada. |
Electrical Problems with ignition
I'm having some problems with my ignition system in an s13 coupe. For some reason the signal wire is not receiving any voltage when i crank the key (the positive side that connects to the starter). Should I just trace the signal wire around till I find the problem? what do you guys recommend?
I was thinking maybe its grounding itself somewhere but im not sure. I bought the car this way, but its time to fix it.... ![]() |
