#31 |
Are those modified j30 hubs for the front?
Keep it up sweet fab work!
@UpshiftEngineering |
#32 |
![]() Join Date: Jan 2012
yes they are, IMO best way to go 5-lug up front. i have looked into every option and it is the beefiest way to go.
thanks man, alot more fab shit to come. thinking about taking a few PTO days at work to get some stuff done sense the weather has started to get nice out here in AZ
Admin- AZSupraCentral |
#33 |
Small update:
got a set of Baller Bolts from intense in trade for my FLCA that i got from them. the Balljoints in them were bad and they were nice enough to take them back. also got a sticker from them so i stuck it to my laptop lol in the next few weeks (most likely OCT. 10-12) i will be taking some PTO days off work just to work on my car. i want to get alot of things done... List: • Finish turbo manifold • Finish welding mount points in trunk for fuel cell • Finish downpipe • Make dump tube for wastegate • Finish up throttle body • New Ball joints for LCA • New bushings for LCA • Rear rotors • install rear five lug stuff • Stitch weld front end • Install radiator • Install intercooler • Install fuel cell • Cut hole for shifter • Mount ECU
#34 |
got some stuff put together this weekend
im going to take everything back apart sandblast it all and rebuild the calipers because they all really need it
#36 |
thanks man
another baby step update lol Ross Machine Racing -8 Fuel rail cut the mount points for the fuel cell, going to try to tack them into place this weekend got these for close to nothing so ill run them till i get coilovers
#37 |
had to make some more clearance for one of the calipers on the dual caliper bracket
#38 |
so little update, things are starting to come together just a matter of getting time to put everything together
The start of my Friday (took the day off to work on the car): diff cover welded: mount points for fuel cell cage: made room to still be able to get to the rear bumper bolts cut off the stock s13 mount points for the Z32 fork mounts: 5Lug stuff all sorted through and ready to go on after i weld on the forks: and what the front end looks like after putting on the lowering springs (needs to go lower):
#41 |
thanks guys
#43 |
thanks man, hope you enjoy will be posting up more soon
#44 |
little update on whats been going on, im actually pleased with the progress ive made in the last few days hopefully i can keep this motivation up
some of the single stuff, i will try to get around to welding the manifold all up this weekend finally got the 240 back on the side of my house (what we call the evil layer) i ripped out all the old rear end stuff
#45 |
big update for me, i got a lot done this weekend and hopefully this upcoming week ill be able to get more done
got the fork made for the Z32 uprights, here is the rusty chunk of steel i started with squaring it up put two slots in it with my Sinker EDM to make it easier for me cut the chunks out on the saw milled everything to size... after that cut that in half and faced the tops...all done now on to welding it on... after that bolted everything on need to do some adjusting to the alignment just so its not so far off but its back on the ground and that's all i wanted this weekend
#46 |
small update,
picked up some new goodies ![]() ID1000's my other injectors were too small for my ross rail and i got a good deal on these so i really couldn't pass it up, my 1200's will be going on my motor for my supra now witch i really needed anyways so it was a win all around greddy cam gears also picked up a FPR got my oil drain flange on my feed fitting too mocked up the feed line while doing that i made sure my gate and downpipe had enough clarance how it was sitting, i took everything off so i can sandbalst it all and coat it then this morning i got the fitting finished that i needed to make my oil cool / remote mount oil filter work
#48 |
lol thanks man
#49 |
just put this on
#51 |
thanks man i do my best
little by little im pressing forward support rods added
#53 |
its just some egay one but i have used them in the past on a lot of builds. as long as you clean them up and port them out they work good, biggest issue i see with them is slag but being that i have done a lot of port work in my past makes it easy and yes i do have the proper tools...not a dermal REAL POWA!!!! lol
#55 |
thanks man
![]() little more love on my lunch :P shaved some weight off the throttle body from some unused stuff will try to sit down tonight and grind off the rest then time to weld it up
#56 |
little update on the throttle body
#59 |
#60 | |
yea its cause the traction control part of the throttle body so it makes them super long, was thinking of hacking some of it off to shorten it but i really don't need to so i will probably just leave it
