S14 sr20det oem top and bottom harness
S14 sr20det top harness and bottom harness.
Top is in great shape and nothing is cut. Bottom harness only has battery ground cut (can be re connected) and one connector wire is broken( can easily be repaired as well). This came off a zenki s14 sr and had a WC ecu. Asking $150 for both. ![]() ![]() ![]() ![]() Sent from my LGMP450 using Tapatalk |
