S-chassis eccentric lockout washers/kits s13 s14 240sx
These kits are designed specifically for the 240sx. Stock 240's utilize eccentric bolts, from the factory to help align the non-adjustable stock toe and camber arms. Once you replace these non adjustable stock arms with adjustable counterparts, the stock eccentric bolts become useless. Hard driving, cornering an especially drifting can cause your alignment to go out of spec but with this lockout kit in place of the stock eccentric bolts, you will never have to worry about your specs changing. The washers are CNC machined from high grade T6061 billet aluminum. These kits include Zinc plated class 10.9 bolts, lock-nuts and the lockout washers.
*The washers may also be purchased separately* S14 Eccentric Lockout kit - $45 shipped S13 (non-HICAS) Lockout kit - $45 shipped S13 HICAS Eccentric lockout kit - $35 shipped S13/S14 non-HICAS Washers only (8pc) - $20 shipped S13 with HICAS washers (4pc) - $15 shipped PayPal: [email protected] **Leave a note when purchasing for which kit/washers you need**
Instagram @Fatlaced40 Last edited by TunanS14; 01-05-2015 at 07:26 PM.. |
![]() Join Date: Jan 2010
I want!!!!!!
