![]() Join Date: Oct 2008
Trader Rating: (131)
ARC, SR Coil Packs, SR Injectors, MAF, Shift Boot, Fuel Rail
I have the following items up for grabs. Shipping is included!
1. Genuine GReddy Oil Pan for SR20DET: MINT, never been installed. Includes the baffles, but needs mounting bolts and a drain plug. I contacted GReddy and they told me that any Authorized GReddy retailer should be able to get you a hardware kit- or you can go to the hardware store and find something that would work pretty easily. I purchased it from another member without hardware, so that is why it is missing. I don't want to part with it, but I could use the dough. SOLD 2. ARC Radiator Shroud/Cooling Panel: In great condition, rare and hard to find. Genuine ARC product. These retailed for well over $200 when new. No major blemishes to speak of. $125 Shipped 3. Custom Shift Boot for S13: I had this custom shift boot made for my car and never installed it. It is black with red stitching. The red is almost a subtle burgandy in some light- I tried to capture the true color in the pics. Includes bottom bracket for a clean OEM install. $SOLD 4. S13 Headlight Cover: Factory pop-up cover for s13. Mint body wise, no dents or dings. Paint is black and slightly faded. Otherwise, no blemishes. Driver's side. $25 Shipped 5. S13 Headlight Shroud: Factory pop-up headlight shroud for s13. No major blemishes, no broken tabs. Driver's side. $30 Shipped 6. KA Fuel Rail: This came with a set of injectors I purchased from a member. A couple of the screws were cut, so I had to cut the heads off. There is plenty of exposed screw to pull out with a pair of vice grips. Includes all 4 caps that screw down to secure the injectors. This may fit the SR20 as well, but I am not positive about that. $20 shipped 7. KA/SR20 MAF Sensor: I had a bad MAF on my SR20DET, so I bought this as a replacement. I have since put the car away and decided to run a Z32 MAF, so I don't need it. I believe it came from a KA, but will fit the SR. Includes 3 wire pigtail. Tested to confirm it works. $30 shipped 8. SR20DET Coil Packs (4): I jumped the gun on replacing my coil packs- I thought that was the issue, but it turned out to be an injector. I have 4 gently used SR20DET coil packs for sale. About 40k miles on them to the best of my knowledge, no issues. These sell for $55 each new and are a special order item from Japan (as far as I know.) (don't have current pics) $60 Shipped for all 4 10. SR20DET Fuel Injectors (4): I have a set of SR20DET 370cc OEM fuel injectors. The pintle caps need to be replaced, and one of them was not firing in my car. O rings look good... (don't have current pics) $40 shipped for all 4 PM me with questions and for paypal info, and check my feedback for concerns about my trustworthiness. Items located in Michigan. I can combine shipping for multiple items. Thanks for looking! Damon Last edited by CamryOnBronze; 11-04-2009 at 02:20 PM.. |
#6 | |
![]() Join Date: Jan 2005
Trader Rating: (31)
does the shift boot have that ring on the bottom of it that bolts to the stock shifter trim?
Slip Gypsies Blog Quote:
#8 | |
Trader Rating: (31)
i'll take the shift boot pm me your paypal bro
