Cleaning out my garage! Lots of random parts that have accumulated in there, most of which I've never even laid eyes on until now! Trying to raise some extra money since I just went SR and have no more use for these CA18DET parts that are hard to find nowadays since the engine is kinda obscure.
Willing to ship at buyer's expense. Located in Huntsville, Alabama. I accept PayPal and WesternUnion! CA18DET Parts: (2) sets of coil packs with harnesses $60 per set obo Intake cam $20 obo Cam gear $5 Starter $30 Timing belt idler $5 (2) Throttle Position Sensors TPS $20 each obo (2) Ignitor chips $20 each (3) Cold-Start valves (aka Air regulators) $15 each *one sold* (2) Idle control valves (aka IACV) $20 each *one sold* (2) Air conditioning idle-up valves $5 each *one sold* Power steering pump $25 Oil pressure sensor (aka sending unit) $20 Intake manifold (JDM 8 port) **SOLD** new intake manifold gasket **SOLD** Dump pipe (aka o2 housing, aka turbine outlet) **SOLD** Valve covers **SOLD** (2) Cam Angle Sensors (aka CAS) **SOLD** KA24DE Parts: full set of transmission bolts (5 speed -- they're rolled up in order in duct tape in the pics) $20 Starter $30 Accel performance coil $20 Spec billet flywheel new with a Spec stage 2 clutch super low mileage $350 for the combo Godspeed intake manifold with OBX top feed fuel rail and stock injectors ran for female connectors and KA throttlebody/TPS $250 Oil pressure sensor (aka sending unit) $20 Idle Air Control Valve (IACV, AAC Valve) with subharness $25 (2) ECU's **SOLD** Miscellaneous Parts: Nismo Type-A adjustable fuel pressure regulator (SR/KA/RB/CA) $100 SR20DET water neck $20 T25/T28 compressor outlet with 90 degree coupler $25 T28 Adjustable wastegate actuator with bracket $25 pipe with flange for HKS ssqv bov $10 brand new Bosch Platinum spark plugs $10 Blitz turbo timer scratched up $20 stock s13 rear calipers $25 stock SR20DET redtop cams (not pictured) $25 SR20DET Oil pressure sensor (aka sending unit) $20 RC 550cc injectors topfeed $250 shipped! Greddy RS bov **SOLD** knockoff HKS ssqv bov **SOLD** TurboSmart wastegate **SOLD** 440cc injectors topfeed professionally cleaned **SOLD** ALL PARTS SOLD AS IS
![]() Join Date: Mar 2012
can i get as package deal for the 2 CAS, exhaust cam and the power steering pump? itll be the exhaust cam if it has the key inside the gear side of the cam. PM me please
CAS's are indeed sold to omgwtf!
And yes I have a twincam KA power steering pump! No adjustable FPR for sale though. And I will trade the dog for OEM s13 heated seats! lol
s13 or s14? not sure if i have one either way, but i can check.
also, power steering pump sold. performance coil added. Greddy bov sale pending.
#20 |
Sell me the following:
1 xCold-Start valves (aka Air regulators) $15 1x Idle control valves (aka IACV) $20 1x Air conditioning idle-up valve $5 how much shipped to 92833? what's your paypal? |
#22 | |
No problem man! Thanks for the positive iTrader rating! I just left a positive for your account as well! (:
#24 |
I don't have any stock CA18DET injectors, but I just messaged my buddy to see if he's got some for sale. I'll let you know ASAP!
| ca18, ca18det, ka24, ka24de, oem |
