cant work out how to add pics mate lol
just shows up with a box with a red cross through it , tryed on another thread , can you tell me how to ??? il try again after work ![]() <a href="http://s1355.beta.photobucket.com/user/DRTY14/media/121125-1437.jpg.html" target="_blank"><img src="http://i1355.photobucket.com/albums/q707/DRTY14/121125-1437.jpg" border="0" alt="Photobucket"/></a> cheers |
#4 | |
It's Always Broken.
![]() Join Date: Feb 2010
![]() Feedback Score: 14 reviews
Hey man. All you do is take your direct link on photobucket and insert in [img][/img] tags
#7 | |
It's Always Broken.
You take the link and put [img]insert link here[/img] around it.
There's also a little image icon when you're posting that you can use instead. You click it and a box will come up telling you to insert the link to your image and it'll insert it for you.
Looks good! So are you you running factory headers right now? Are you going to have custom ones made or do you know of some aftermarket ones available? I have a vh41 also and there's not much aftermarket for it.
#10 | |
he works at Limitless Performance and Fabrication in Huffman TX. go to v8nissan forums mate hes on there good luck to ya |
cause there not as tall ,
was told by a few people that use them in jet boats and they said they rev out better , it was available , the 41s are more common in new zealand , ![]() is that ok lol ? hard to please some people . . . . . ![]() |
#15 |
![]() Join Date: Jun 2009
i doubt the vh41 is any shorter than the vh45, iirc it is the same block destroked via crankshaft
vh41 is weak readily available i can llive with no need to be a dick |
#16 | |
Its alternator is also located at the top of the engine which creates an overall narrower engine package which can be handy in engine conversions where it may otherwise foul on the chassis rails. and thers not much room in the s chassis at all ![]() and the 41s are strong enough for me mate im not puting boost up it . cheers |
#17 | |
Nice swap! Nice to see there are some people going V8 but staying Nissan! |
#18 |
![]() Join Date: Sep 2008
The JDM 41 like his is actually said to be the better engine. Just like he said, a lot of people in NZ and AUS use these engines in all sorts of cars and boats, even build 400+hp "streetstock" race cars. There are also many 600+ hp stock block turbo 41s out there.
-Mike |
