help with my POS sr20! (vids & pics)
well i got my motor in (s13 redtop sr20) but still running into some problems.
i have a nipple on the intake manifold side that i cant figure out where it goes? any one have a clue, heres a pic: and i checked over my entire wiring harness (ka harness) and i cant find a clip or anything for this. can i run without it or is it important: and last but not least when i had everything in except for that hose and the ground clip, this is what my car would do. it wouldnt turn over or anything, the clock would just lose it's light and that all. |
![]() Join Date: Feb 2008
Just cap the nipple off if you cant find anything that goes to it.
The sensor is for the temp gauge in your dash. Is your starter hooked up right? Which lower harness did you use? |
![]() Join Date: Dec 2005
that nipple is fpr the throttle body. Its for emission purpose however i would reccomend connecting it if you live in a cold climate as it improves drivabilty.
does the starter click at all when you turn the key?
if it doesnt, you might not have it wired right. if it does, your batt might have enough juice or the solenoid is dead. when i first did my swap, the starter would just click. i swapped the solenoid from an extra starter i had and it fired right up. |
i hear the relay click once, but the starter doesnt do anything. and the car was always a 5-speed. what about that sensor, how would i figure that out, the temp gauge worked before, but i checked the harness and theres no clip or anything.
![]() Join Date: Jul 2008
the one sensor on the left the yellow one is the temp sensor to the ecu it tells the computer to run rich or lean depending on coolant temp the other smaller one is for the cluster in side the car it is only a one wire and should be black dont quote me on that but i belive that it is black as for you starting from watching the vid whay dont you mount the battery down and check all your connections relays fuses also check voltage at the battery and the starter hope this all helps let me no
![]() Join Date: Apr 2005
Dont do that. charge your battery. the nipple is for coolant to your Tb as already stated. you can loop it to the return side of the tb loop or just get the hose. and the coolant temp sensor is correct, the thing is useless. get a real gauge. |
im on the west side of town, all the help would be great, i'm gonna go out to the garage for alil bit and hook the stuff up, also theres another problem i forgot about:
my clutch is very very very soft, and it;s a brand new ACT 6-puck clutch kit. i took the dampen box out and bled the clutch line but still weak, possibly the master cylinder? |
#17 |
i guess i will try and find a master cylinder and try that, but like i'll push the clutch down and it's real easy, and sometimes it wont come back up, and if it does it will come up like an inch
#20 |
i bet you still have air in the line, try doing one pump at a time (pedal down, open valve till fluid stops, close valve pedal up, repeat) . it's tedious but it works better. or splurge on a speed bleeder
#21 | |
![]() Join Date: Apr 2008
1993 AW Mazda RX-7 1997 Nissan Silvia |
