![]() Join Date: Sep 2011
rack and pinion bushing replacement question
Do I need to remove the whole rack and pinion in order to replace the bushings or can I install still attached?
Then slip the new ones on and re-mount the bracket. That's if I recall correctly, haven't done that shit in a long time. But I don't recall having to remove the entire rack. Someone correct me if it's just a bracket holding them onto the rack or something else.
White '90 S13 Fastback (SOLD in '07) |
![]() Join Date: Jul 2006
Just to help you out, i'lll make a cgi cartoon of a anime warrior, turned drifter, changing out his bushings on his sweet 240.
If you won't take the time out to look under your car to see what you might be getting into ( for the sake of learning ) you shouldn't be working on your car. Just take it to a shop and pay them to do it. |
