S13 Fuel Pump
Hello, Everyone
I am having problems with my fuel pump not getting power? I have total re-built my DOHC KA. New fuel pump installed because the old pump stopped working. I checked the pump with a volt meter no power. Any idea's how to fix this problem. |
I just had the same problem, having a multimeter helps a lot haha. There is only one relay, labeled EGI in your fuse box. it's green. the fuse is next to it, (red 10amp) that's what my problem was. If the fuse/relay are good you should hot wire the pump to see if it turns on, that way at least you can rule out bad pump.
