Old 03-10-2018, 12:06 PM   #1
azsr20det
azsr20det is an unknown quantity at this point
Dash cluster fuel gauge not working
So when i bought my S13 in 2010 the fuel gauge didnt read. I figured the float came off the arm so now that im finally working on the car almost a decade later I pulled the pump and sender out and the fuel float is infact attached. Heres a pic
Any ideas why its not working? I bought an aftermarket fuel level sender and gauge but id really prefer to fix the stock unit before I go throwing aftermarket parts im there.
Any ideas?
azsr20det is offline   Reply With Quote
Old 03-12-2018, 10:33 AM   #2
azsr20det
Nobody has any idea where to start diag on this problem? Fuel systems and electronics are def not my forte :/
Old 03-22-2018, 12:02 PM   #3
azsr20det
Nothing? The sender seems to be putting out the correct ohms but the dash cluster isnt adknowledging it
Old 03-29-2018, 01:47 AM   #4
teejayhoward
teejayhoward is an unknown quantity at this point
Pull the cluster. Find the pin on the cluster that corresponds to the fuel gauge. Test the reading at that pin on the harness side. If you're getting the right reading, you have a bad cluster. If you're getting a wrong reading, you've got a short in your harness somewhere. Trace the cable back to each connector in between the cluster and the sensor, testing at each step. When the readings come out correct, you know where the fault is.
teejayhoward is offline   Reply With Quote
Old 03-31-2018, 09:55 AM   #5
gaz_moose
gaz_moose is an unknown quantity at this point
how does the circuit work?? does it measure resistance to ground? if so I would just earth the plug out and see where the gauge goes. if it moves you know its good.
gaz_moose is offline   Reply With Quote
