![]() Join Date: Jun 2005
**Update 11-23**
Rebuilt KA24E now has close to 5k miles. Only issues: Idle hunts between 600 and 900 rpms, CEL is on Yesterday (11-22), I pulled the code: 32 - EGR function. Cleared it in ECU without replacing EGR. Idle screw in ECU in same position before I did diagnostics Now the car stalls, won't hold idle. Borrowed a vacuum tester from autozone, the tube is too big for the EGR valve so I didn't get to test EGR valve. I have the EGR valve on order, will get it Friday. Any other parts I should look at? Thanks **Update 5-10: Now with spark and timing redone 5+ times. ** This is the 3rd sohc i've swapped in my '89, the first as a fresh rebuild. The other two were used. I'm not getting any spark. The first 2x that I've swapped in a sohc, it started right up. It has: new spark plugs new coil <-- after doing search spark plug wires are still pretty new it is getting fuel wire connections checked/rechecked I've tried: 2 different distributors; 2 different distributor caps; adjusting to Top Dead Center (TDC) 1x sunday, 2x today Car ran before the swap, but had a bad head gasket, which is why I got a rebuilt engine. Any help would be greatly appreciated.
71, 72, 74 Celicas; 85 AE88 hatch; 89 S13 hatch; 04 IS300 5MT Last edited by gripster; 11-23-2011 at 08:52 PM.. Reason: new issues |
Fuses are good.
Found a loose wire connection to the tranny, but I know that has nothing to do with ignition.
71, 72, 74 Celicas; 85 AE88 hatch; 89 S13 hatch; 04 IS300 5MT |
![]() Join Date: Sep 2009
![]() Feedback Score: 27 reviews
Wire harness grounds? The part that run in between valve cover and fuel rail. there are like 2 grounds that need to be attached to the engine near the powersteering pump.
Ok folks,
I now have spark, I have fuel (I can smell gas from spark plugs), and timing was checked/rechecked more than 5 times, but still won't catch. It sputtered twice, that's all I got. Fuel goes to fuel filter --> Fuel Pressure Regulator --> to Fuel Injectors, right? Or am I missing something?
![]() Join Date: Aug 2005
9 days old, but hope you see this before you tear your hair out.
Fuel pressure regulator comes after fuel rail. Fuel regulators operate by backing up fuel into the fuel rail until a certain pressure is reached, and then opening to allow the excess pressure back out of the rail again. Fuel should go pump ---> filter --->rail ---> regulator--->return
This is my clever and witty signature. |
daryl had it right, got my fuel lines mixed up.
Timing was also still off. Finally got the car started, but lost compression in #4 cylinder. Shop rebuilt it again under warranty. Thanks for the help! Much appreciated.
71, 72, 74 Celicas; 85 AE88 hatch; 89 S13 hatch; 04 IS300 5MT Last edited by gripster; 11-23-2011 at 08:55 PM.. |
I've got a new issue after clearing the CEL. See 11-23 update.
Any help will be much appreciated.
