I have TD05 16G with manifold and downpipe to fit SR20. The question I have is will the engine run if I’ll run it on stock boost (7psi) without a tune?
![]() Join Date: Mar 2009
It will start, idle, and run fine. You're going to want to get it tuned to drive in boost safely.
Also, stock s13 sr20det boost pressure is variable between 10-12psi via the factory boost pressure solenoid. Wastegate pressure is 7psi. |
Thanks, that exactly what I needed to hear. I guess I’ll ride stock for now.
