I need help disabling my factory alarm. Right now the cars alarm won’t stop going off. I’ve tried all the little tricks people say to do with the key and the valet button. Well the wires are cut behind the valet button. The key doesn’t unlock the trunk. Please help.
I don't think the factory alarm has a valet button. Look for some kind of aftermarket box under the dash. Most of the time the wires are tapped into the ignition wiring, so you should be able to trace it out if not readily visible.
