![]() Join Date: Jun 2013
Trader Rating: (25)
![]() Feedback Score: 25 reviews
UP FOR GRABS IS MY HOLSET! HX35W FULLY BALANCED, AND POLISHED! freshly rebuit as well. $550
Both the compressor and turbine housings have been powder coated (turbine-black, compressor-silver then polished). The turbo has normal bearing play, no shaft play(slight wiggle). This turbo is set up for use with an external wastegate as the internal wastegate has been welded shut. If you want to use the internal wastegate, just grind off the weld and it should free it up. $550 SHIPPED, and insured. ANY WERE IN the U.S. another!! HOLSET HX35W TYPE D ( OFTEN MIS REFFERED TO AS HE341) FRESHLY REBUILT, AND BALANCED!! $ 400 shipped to lower 48 States. (dont have the specs for the A/R trim at the moment or housing sizes on both turbos) at work right now.....but I do believe they have 12cm ex housings. BOTH TURBOS ARE 7-BLADES. Last edited by adams 02rs; 02-09-2015 at 07:10 AM.. |
