Old 10-24-2016, 06:35 PM   #1
Sileighty_85
Sileighty_85's Avatar
SR 1986 SR20DET Corolla GTS
Testing the waters here, really love this car so kinda hard for me to part with but the right amount may persuade me.
Asking 5,500$ Negotiable
NO TRADES
As the title states it's a GTS Corolla. Car has been in storage for the last 4 years but runs and drives with no issues other than a sticky starter solenoid. Car rolls out through, .8 bar and it will roast the tires through 3rd gear.
I was building his car for my wife for her drift car but then got moved to Japan for 4 years so never got to drift it and came back with a pair of skylines and a daughter so priorities changed a little bit.
For those of y'all not familiar with the car I have a build thread for it here on Zilvia so you can see what all was done to it.
#/f/showthread.php?t=410133
Electrically everything works like OEM , headlights, tail lights, blinkers, wipers, heater.
All OEM chassis wiring was retained, so if you wanted to install a 4AG back in the car you'd just need the engine harness and it will plug right in.
It has an S13 SR20DET
Lower pan was pulled and cleaned prior to install
Blitz FMIC
Greddy MBC
HKS Pod filter (needs new filter)
Walbro 255 fuel pump
Aluminum radiator
Greddy coolant temp gauge w/ new sensor
Blitz boost gauge
New clutch master cylinder and slave
Legit adj. HKS BOV
Mr copper exhaust gasket
Circuit sport steel braided turbo lines
Footwork and Drivetrain
Stance Coilovers, less than 500 miles on them.
Engine bay and cabin stitch welded
T3 rear 4 link
T3 Panhard bar
OEM Manual Rack
T3 adj. power steering knuckles
Moog inner tie rods
T3 adj. outer tie rods
New rotors and pads installed before storage
TRD 2way Kouki LSD and 3rd member w/ weir performance crush sleeve (needs to be reshimmed)
3 Kouki 25mm axles with new bearings
New front bearing rebuilt kit
Custom 1 piece steel driveshaft
Custom shifter to maintain OEM placement and no cutting of interior parts.
FC RX7 4 pot calipers (not installed)
Body
OEM JDM trunk spoiler (not installed)
Hoshino Impul G5 wheels
There are a few other things in probably missing too.
There are some little things that need to be done that I never got to take care of before putting the car in storage. I.E.: getting the speedo to work and making the engine mounts look prettier, refabricating the tranny tunnel from the PO, finish shaving the rear parking lights.
Chassis is in great condition aside from some dents and dings and a few little rust spots.
Title is clean and in my name.
These pics are back from when I was putting the car together and before the car went into storage.
Car is located in Mobile AL, so a car transporter would be need.
Most recent shitty pic I have of the engine bay.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 10-25-2016, 09:01 AM   #2
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
tits!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!
supersayianjim is offline   Reply With Quote
Old 10-27-2016, 10:04 AM   #3
Sileighty_85
Bump!!!________________
後輪駆動車1番
1986 SR86 - 200ish
Old 11-10-2016, 04:51 AM   #4
Sileighty_85
To the Top!!!
後輪駆動車1番
1986 SR86 - 200ish
Old 12-06-2016, 08:21 PM   #5
Sileighty_85
Holiday Pricing!
後輪駆動車1番
1986 SR86 - 200ish
Old 12-07-2016, 05:36 AM   #6
Chipskream
Chipskream is an unknown quantity at this point
If it is still around in March I would love to pick it up from you.
Chipskream is offline   Reply With Quote
Old 02-09-2017, 05:46 PM   #7
ricky508
ricky508 is an unknown quantity at this point
That thing is sweet...hurry up tax money! Mobile, AL isn't far from me...definitely worth the trip
ricky508 is offline   Reply With Quote
Old 02-12-2017, 05:52 PM   #8
Sileighty_85
Sorry guys forgot to update this but the car is pending sale they should be picking it up on the 18th
後輪駆動車1番
1986 SR86 - 200ish
Old 03-02-2017, 09:09 PM   #9
Sileighty_85
Car is sold
後輪駆動車1番
1986 SR86 - 200ish
Old 03-03-2017, 04:56 PM   #10
idlebad
idlebad is an unknown quantity at this point
Originally Posted by Sileighty_85 View Post
Car is sold
Well congrats at least on making a few bucks!
idlebad is offline   Reply With Quote
ae86, hachi, sr20
