hey,
got a strange problem with my gauge cluster, thought it was broken so put in a new one but got the same issues.. positive: -watertemp works -distance counter works negative: -rev jumps one time when i turn the key and stay at zero then -speed vibrates at zero -fuel doestn work at all - by braking the left turn signal turns on in the dash (but my light is broken, but should be on anyways i guess) solutions? -new cluster --> same issues - ... ? Where should i start? The signals are all independet: Fuel --> pump , speed --> gearbox, rev --> ecu DAFUQ? |
it has to be some ground problem.
can anyone help me how to locate this? where should i start and how to measure right? any tactics by looking for wrong ground? please guys im lost in this electronic shit |
| cluster, dash, problem |
