| Archive and FAQs Archives and Frequently Asked Questions about the 240SX are in here. |
AutoX Junkie
Post informative offset links or quotes...
#/forums/cgi-bin...m=2&topic=1471 http://www.tirerack.com/wheels/tech/offset.htm (edit*)Courtesy Matt (mdsdm) from 240sx.org </span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE"> original wheel width = a (in inches) original wheel offset = b (in mm) new wheel width = c (in inches) new wheel offset = d (in mm) difference in clearance on the inside between original & new = f (in mm) difference in amount the wheel sticks out bewtween original & new = g (in mm) f = ((a*25.4)/2 + b)-((c*25.4)/2 + d) g = ((a*25.4)/2 - b)-((c*25.4)/2 - d) </td></tr></table><span id='postcolor'> |
Married to the Mob
Here's more info:
-Offset is the distance from the front of the hub-mounting surface to the center of the wheel. -Zero offset means that the hub mounting surface is even with the centerline of the wheel. -Positive offset means that the hub mounting surface is toward the street-side of the wheel. -Negative means the opposite. (towards the axles). ------------------------------------------------- Edit: Never mind, I just read Lance's link. |
