s13 partout five lug boostcontroller t28 lots of good parts
Motor.
Sr20det blacktop blacktop e5 ecu Still has all sensors exept tps and maf New oem alternator list price 840 has 6k miles $200 T28 turbo stainless steel braided lines for water and oil new elbow, new o2 housing, new adjustable wastegate, looks and was working great $600 New water pump hardly used. New thermostat hardly used. Custom valve cover shaved and painted black. Godspeed fmic only used for about two months only imperfection is a small dent. $160 Hks ssq BOV $80 Blitz spec r dual solenoid boostcontroller have everything even box. Hardware and instructions in japanese. Good condition$150 Greddy boost, and oil pressure gauges in black, with steerring column tower, all hardware required in excellent condition. $180 Nismo motor and tranny mounts. Megan tension rods $80 Lcas great shape$60 C's short throw shifter all hardware is there $100 Z32 calipers aluminum 30mm great condion except minor scratch on passanger side front. Need some tlc paint with slotted rotors still pretty good can be turned. $280 Stainless steel braided lines front two fittings need to be replaced otherwise great condition. $50 Ichiba hubs 6k miles on em $220 Nismo extended lugs still in box new $60 R32 vlsd diff with axles $110 Walbro fuel pump $50 R32 gtst rims sumitomo tires 5k miles 95% tread $450 Z32 tt rear rims(perfect) and three mismatched na and tt rims $100 ***Got tons of other stuff inquire within reach me at my cell for fastest response OMAR 9098152311*** |
| s13, sr20 blacktop, t28 |
