| Polls Post All Polls in Here. |
| View Poll Results: Time to change oil | |||
| When the oil changes color |
22 | 14.67% |
| Every time you wax your car |
6 | 4.00% |
| At 3000 Miles |
106 | 70.67% |
| When I feel like it...it is black and nasty. |
23 | 15.33% |
| Multiple Choice Poll. Voters: 150. You may not vote on this poll | |||
#31 |
![]() Join Date: Jan 2004
I use red line 10w30. Even though it says recomended oil change in 12-15k miles, I change it at 3-4k. You can tell me Im wasting money, but I just have a deep love for my motors.
#32 |
![]() Join Date: Sep 2002
I've been using redline in my KA for 3 changes now and everytime i change it (3k first 2, 5k the last one) it's been black as hell. But when I go to fill it up again almost ALL the varnish I could see before is gone now. Ima keep using it and maybe down the line I'll do some UOA's.
My 240 vBgarage |
#33 |
Its good stuff. I buy it in 12qt cases off ebay for $70 shipped so its not that bad on $. Also royal purple has about the same deals, maybe 5-10 $ cheaper, but are just as good.
#34 | |
I use Mobil 1 full synthetic, 10w 30, get it at Wal Mart for 19.82 regular price or for 17.88 on sale.
#36 |
you dont have to change it at 3k (That # was made up by the manufactures in order to produce more income for dealerships) Oil is actually good for more like 4-6k depending on your driving habits. (In the case of drifting I would change every 3k or when ever the oil becomes black. (If Synthetics used you can put off changing a little longer)
#37 | ||
#39 |
With synthetic oil you really shouldn't need to change it more than every 4000-5000 miles unless you are really beating on it. I think Bill is on target with checking the color.
#40 | |
^^^ Leaving out the times with which the EXTREMELY anal-retentive will use to change theirs, like the ones who are prepared months in advance for an oil change?
#41 |
Lots of folks change oil every 3K or 3 months.. it's what the oil manufacturers have spouted for years and years and it's become the way you're "supposed" to care for your car. This is a lie..
The detergents in regular oil really have very little to do, IF you run your car till it's completely warmed up (like a long trip on the freeway) once a month. The oil will trap the contaminates and they will disipate with heat. Oil changes depend on load, and type of driving. IF you are driving stop light to stop light, going to the grocery store, the post office.. etc. and never driving it out on the freeway or ever getting it fully warmed up, the 3000 mile rule is a GOOD one. IF you are driving the crap out of your car, getting the engine up to full operating temperature OFTEN, then 6 - 9K between oil changes isn't gonna make a whole hill of beans difference in how long your engine lasts. As for the color of the oil.. clean oil is a GOOD thing, but just because it turns a little brown doesn't mean it's life is over.. of course if it's black and sludgy that's another story. As long as the oil still flows freely, and doesn't stink to high heaven it's probably ok.. Drifting is tough on rear ends, and tires and suspensions, but high engine RPM and heat in the engine is a GOOD thing (to a point), it burns off most of the contaminates from burned and unburned fuel in the oil, and what doesn't get burned off gets trapped in the filter. Engine wear isn't the biggest issue. Neither is the type of oil you use. You are going to wear out your entire suspension, tires and differentials LONG before you're gonna wear out your engine. Synthetic oils will make your engines last longer.. but what is the point? The car is gonna be trash LONG before you can wear out your engine doing regular maintenance and using conventional oils. i change mine at 3,000, because i do city driving and aone every two weeks i go do a canyon run or 5. |
#43 |
what filter does everyone use? I always use the Fram ones just because they are always right there... but what's actually a good one?
![]() I can't, but Chris Brown sure can. |
#44 |
I've been using mobil1 synthetic on my RB for a while and i've noticed it turns black really quick and my engine kinda eats the oil fairly quick
#45 | |
My oil gets changed with mobil1 15w-50 every 1000-2000 miles due to track duty. I change my filter every 2000-4000 miles using a mobil 1 filter. One of the next things on my list of things to buy is an oil cooler to help prolong the life of my oil and to keep the engine cooler. |
#46 | |
i used mobil 1 before.... and i changed it every 3000... but i figure that using castrol gtx and changing it every 2000 mile might be better (cleaner oil cause less miles) and it's cheaper than mobil 1. what do you guys think??? |
#47 |
Extended Oil Drains and Used Oil Analysis
'90 S13 110k mi, 10w40 (dino/conventional valvoline, chevron, mobile), amsoil filter. Daily driving.
1st change: 3500 miles / UOA indicates drain interval can be extended, sufficient TBN levels remain. Insoluables level normal. 2nd change: 5000 miles / UOA indicates drain interval can be extended, sufficient TBN levels remain. Insoluables level normal. I'm trying 6000 and 7500 miles next. The oil changing color is not necessarily an indication of an oil change being required... if anything, it means the oil is doing its job- cleaning. Oil is still good if the level of active cleaning agent(s) is sufficient, the filter is keeping the level of insoluables low, and the viscosity level is within an acceptable range. |
