![]() Join Date: Apr 2008
afc settings ..help!!
tryin to get an idea so i can atleast drive my car around till i get tuned..some one help me out..370 inj,excessive intake,10:5 90 pistons,headers,exhaust..have a ruff and kinda low idleround 7-800 instead of 950-1000..revs fine but soon as i push the clutch in its starts to bog and wanna stall out..heelp!
stock maf,kade from a 91 brand new afc neo,5 in 5 out for hotwire..thats what i found..the idle is kinda crappy when the afc is hooked up and idle fine with out it..i ben tryin to figure this crap out for the last 2 weeks
![]() Join Date: Nov 2004
What the fuck do you have injectors for?
What the fuck, are you trying to blow your motor? Get a real tune. What the fuck, KA's don't have headers. What the fuck, Ka's are SUPPOSED to idle around 700rpm. what the fuck what the fuck what the fuck
was it running fine before you dicked with the car? and if its running fine without the afc you probably have it hooked up wrong. imo
how are you measuring your A/F ratio?? an safc is useless unless you know what kind of fuel ratio you have while you're tuning it. you're probably runing too rich with the 370cc injectors and a stock maf. Get a wideband or measure the voltage of your O2 sensor to find out if you are running too rich or lean.
