Old 01-06-2013, 12:06 AM   #1
rwtf
rwtf's Avatar
rwtf is an unknown quantity at this point
SR Apexi turbo timer help?
I got the Circuit Sports TT harness from FRsport, also I have the pdf manual for the TT.
I was reading through it about the 3 extra wires, the white, black and grey.
I know grey goes to the Ebrake switch, black is ground and white, goes to the O2 wire going to the ECU, or so the manual says. I want it to give me A/F ratios.
so my question is does the white wire actaully go to the O2 on the ECU, I've read that it taps in to the speed wire and also the tach signal? also that for it to work the ground has to be spliced into the ecu?
btw, its a 89 hatch, with an kouki(I believe) s14 sr20det.
rwtf is offline   Reply With Quote
Old 01-06-2013, 09:32 PM   #2
DennisC
DennisC's Avatar
DennisC is an unknown quantity at this point
Tap it into the o2 sensor signal wire. I have the same turbo timer and I have the A/F reading working on my KA.
DennisC is offline   Reply With Quote
Old 01-07-2013, 12:10 AM   #3
rwtf
rwtf's Avatar
thanks for the reply, did you ground it to the ecu? as the pic shows the dotted ground saying if you dont use the 02 signal, it was kinda confusing, do I have to do it that way?
Old 01-07-2013, 12:38 AM   #4
DennisC
DennisC's Avatar
Yea I tapped into a ground from the ecu and grounded the unit to it. I'm pretty sure it will still work fine if you ground it to the chassis.
Old 01-07-2013, 02:00 PM   #5
rwtf
rwtf's Avatar
thanks for the help!
Old 01-07-2013, 06:39 PM   #6
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You have the PDF instructions and you cant follow it? It says right ground the black wire if NOT using the o2 sensor signal. Since you're using it, then tap it into the ground into the ECU.
CLICK HERE!!!
Old 01-12-2013, 06:16 PM   #7
rwtf
rwtf's Avatar
I only hooked up the ground and tapped the grey into the parking brake swtich but now my parking brake light doesnt work and cant get the timer to work...wtf?
Old 01-13-2013, 09:58 PM   #8
rwtf
rwtf's Avatar
alright found out my bulb was gone and fix it. but my turbo timer will NOT work, I turn key to the ACC it comes on, ebrake is up, but it wont let me change any of the settings i can only go up or down, or hold it to the left and it say "off"
I have the black wire grounded to ebreke, and the grey spliced with the ebrake switch. wtf am i doing wrong....
Old 01-16-2013, 07:10 PM   #9
rwtf
rwtf's Avatar
bump.....
Old 01-21-2013, 05:49 PM   #10
rwtf
rwtf's Avatar
anyone...........?
Old 01-28-2013, 02:35 AM   #11
DennisC
DennisC's Avatar
Are you sure the circuit sports harness isn't wired wrong? It should only turn on with the key in ON position and as long as it detects that ebrake is grounded, you should be able to change settings.
Old 01-30-2013, 12:36 PM   #12
rwtf
rwtf's Avatar
how would it be wired wrong? it comes on, everynow and then i will start the car and it will count down. And nope cant get to the settings, with ebrake up or down.
