![]() Join Date: Sep 2005
Trader Rating: (48)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 48 reviews
s14 manual ecu 98,xxx~SOLD s14 5 speed transmission 98,xxx~$300 S14 diff cover~$25 transmission tunnel covers~$40 ka24de spec stage 4 clutch & flywheel 200miles~$500 auto meter 2 guage pod~$20 s14 sr oem fuel rail~$20 s14 sr intake manifold,tb, iacv~$120 non abs drive shaft(man/auto) ~$100 auto crossmember~$15 man crossmember~$25 plate between transmission/block~$25 elec fan controller~$40 oem s14 suspension 98,xxx~$125 s14 tension rod brackets~$40 s14 drivers side lca(good condition)~$75 s14 coil pack cover~$10 hot side ic pipe~$20 k&n air filter/no name filter~$10 each s13 black top valve cover(broken tab, good for s13.4 conversion or fix it)~$50 climate control unit(s14)~$20 godspeed fr/rr lca bnib(only test fitted)~FRONTS SOLDrear $200 z32 bmc 1 1/16 ~$75 z32 rear caliper~$35 adj fpr not sure who makes it~$40 s14 man brake pedal~SOLD s13 sr valve cover gasket~$15 audio bahn 12" sub(knicked but works perfect), ported box(cotton stuffed),800watt amp~$350 ka24de lower harness uncut 98' s14 @98,xxx~$125 All of my prices are NOT SHIPPED. Will negotiate to an extent, trades welcome(I have a 97 s14)
![]() Do you suffer from vaginal dryness... Last edited by Pblesh85; 05-22-2011 at 04:06 PM.. |
![]() Join Date: Sep 2010
I am VERY interested in the following
1) both ft & rear Godspeed control arms 2) S14 clutch pedal 3) S14 5spd non-abs driveshaft 4) all neccessary boots that seal opening for shifter 5) gauge pod 6) uncut lower wiring harness, not sure if it will work on 95 SE Please pm me your best prices each shipped to 33765 and also give me your best price on everything shipped to 33765. Thank you very much for your time. |
Man I wanted those lower control arms soooo bad but I think I am gonna have to wait until I get my 5spd tranny swap done. I will def check back and see if ya still got them. GLWS man they are def good price.
460
2 bump limit. You can start new thread in 3 days.
