#91 |
Great conversion, big fan of the red cam covers!
#92 |
![]() Join Date: Apr 2010
So a little update...
My radiator was pretty freaking clogged up causing the 1UZ to overheat =( no blown head gaskets but now the engine is noisy and has this slight tapping sound. I'll pull the motor later on and see what's going on. So I got me a new radiator since I still had warranty. Threw that on and works like a charm except for those noises in the engine... Took my car in to Mercedes Benz for a tire change... Then sold my wheels to and bought the same wheels again but in bronze and brand new... Wrapped them in 225/35R18 Hankook up front and 265/35R18 Continental at the rear... |
#94 |
Man this is a badass engine swap! On another note, noticed a carbon fiber hood in these recent pics....what brand if you don't mind me asking, and you using hood pins? Sorry for so many questions lol! Great build keep the updates coming
#95 |
I don't remember what brand it is but I bought it a little over 1 year ago. Still has the clear coat nice and glossy. I'm not using hood pins either. I'll install those soon.
#106 |
![]() Join Date: Jul 2012
I'm loving this! Your S14 looks amazing. I have been putting together my 1uz swap since January, going VERY SLOWLY... :P I have mine in a '89 shell I'm piecing back together, planning on finishing next year so I'm emissions exempt.
#107 |
he has sold this car. he now has a wrx wagon and is building a 1uz s13 coupe.
#108 |
That is correct zenkiset... I actually traded my s14 for a Subaru WRX Wagon. I got a baby on the way so I had to put my priorities first. But it doesn't stop there... I have an s13 which I will build also with a 1uz engine. You guys can follow me in Instagram under sezio_g to check out my progress and work i've done. Thank you all for your support! But please stand by for something greater!
#109 |
DANG sucks you sold this...itd be nice to get some advice for a ka trans in my ls to 5 speed swap.
minus the ls motor and ecu how much did it run you to simply be able to use the trans with the 1UZ?
OKSTANCE.COM FANBOY HATE MAGNET |
#111 |
if i can 5 speed swap my LS all for around 1-1500 with parts that would be so worth it!
thank you sir! wonder if id be better off trying to find an sr trans tho KA's are pretty much free
#112 | |
![]() Also i would advise NOT putting a KA transmission in a Ls400. They are not that strong. ![]() This was with a SR and 245's. I would suggest a r154 or a 350z trans (they're cheaper than you would think. I picked mine up for $300) |
#113 |
Dang shoguner lol you sheared off that gear! My KA trans did pretty well. Then again I daily drove my car more than anything. I did have plans to use the 350z tranny though.
#114 |
It was my friend's car. I used a 350z trans right off the bat.
#116 |
if this was going to be anything other than my daily driver I would not use the ka tranny, but it will be my daily. very little beating on this thing and little to no clutch kicking. but as soon as I can find an s13 vert to daily, the 1uz s14 will deff be upgrading to a 350z trans and be turned into a track car.
but first things first.. I gotta finish the swap before any of the others can happen lol. |
#117 | |
