Well boys the season is fixin to open! Hope all you racers out there are ready to roll, Im almost! Few more Nic nack pieces to install to be legal.
So what are your plans and times your hoping to do/get this year? Im looking for a 6 flat 1/8th mile and a high 9 - low 10 sec 1/4 mile with the new propane setup! should be an interesting time! I have a new suspension setup along with ALOT MORE POWER! launch control, and a good tire combo. ![]()
Well I got delayed and my setup got threw off alot. I ended up Breaking more parts over the 2008 season leaving me short of my goals.
Although I didnt get the Propane or my Bigger turbo on yet. I just Started my Conversion to Propane this week. I should be on the Dyno in 2 weeks. Im going to a MegaSquirt ECu to Adjust my timing with and I have a 60mm Precision Turbo thats going on within the next few months. I had a Few issues with my 2step this year. I believe I got it worked out tho, But I Killed my coils in the process. Im switching over to the Ls1 coils and that will take care of my spark issues. Anyone else have any better luck this year?
![]() Join Date: Mar 2007
This year. with street tires and 2.0 60 fts. I ran 7.60 in my evo 8. 1/4th ran 11.1. with 1.9 60 ft. I really need tires! If I can get my proper tires and proper 60 ft's like 1.5 I should be well In the mid low 10's
1/8th : 7.60 @ 95 mph 60 ft 2.0 1/4th : 11.1 @ 130 60 ft 1.9 miss shifted into third... I need much Improvement 03 evo 8 80k miles stock tranny and diffs gt30r tuning tech turbine,Hks 272/272 cams.calibrated 690cc denso Injectors,tuned on 101 octane @ 24psi... Full street trim and weight..
Obliterate |
