9:1 mostly stock sr question
I'm currently rebuilding my engine and I havent found an answer in regards to what I need to do to run 9:1 on my motor.
Mods are just 87mm 9:1 supertech pistons and a 1.1mm head gasket. Stock turbo and everything else. Do I need to change anything since I'm going to run 9:1 pistons? |
![]() Join Date: Nov 2010
Not technically, just make sure you have a way to tune the motor for the higher compression.
