![]() Join Date: May 2013
RB and S14 partout.
PICTURES CAN BE FOUND HERE: DO NOT PM ME MY INBOX IS FULL! https://drive.google.com/open?id=0Bw...UFyYndoSkI3TDQ https://drive.google.com/open?id=0Bw...UFyYndoSkI3TDQ https://drive.google.com/open?id=0Bw...UFyYndoSkI3TDQ https://drive.google.com/open?id=0Bw...UFyYndoSkI3TDQ https://drive.google.com/open?id=0Bw...UFyYndoSkI3TDQ Everything is for sale including the shell. I am located in Elk Grove Village, IL 60007. 30 mins away from the city. The best way to reach me is via email or text [email protected] 224-534-9271 Text only do not call me. I work all day and don't have time to talk. HKS Cam Gears $220 shipped Splitfire coil packs $old PROEFI with all sensors and CAN display logger $3250 shipped Aeromotive fuel pressure regulator $125 shipped Driveshaft shop 900hp axles (s13/s14 5 bolt) $1100 shipped Koyorad radiator with fans $250 shipped Tomei Xpreme Titanium for S14 $720 shipped Raw Brokerage Fuel System (Includes adapter plate, Dual Bosch 044's, fittings to lead to single line, mounting plate, brackets, anti-surge tank) $2100 shipped HKS Hipermax IV coilovers $1100 shipped ID1300 Injectors $old Polished intake manifold with 102mm throttle body $500 shipped JGY Fuel Rail for RB $150 shipped Aluminum Drive shaft (s14 to rb) $350 shipped or 300 picked up 1000hp+ capable cylinder head ***pricing will be placed for this soon R33 GTS-T RB25 RWD Trans (healthy, no grinds, shifts beautifully, has 3000 or less miles on rebuild) $old Tomei Short Shifter for RB25 trans **RARE item** **$old Exedy twin disc clutch $800 shipped Tomei cams for RB25/26 $425 shipped Greddy Oil Cooler with relocation plate for rb25/rb26 $750 shipped Raw Brokerage intercooler kit $1200 shipped Sikky Sway Bar $200 shipped Status Racing Seat $750 picked up or $800 shipped Manley Turbo Tuff Rods with 625+ hardware $1200 shipped Eagle Rods (ARP2000 hardware) $500 shipped Raw Brokerage Twin Scroll T4 Divided Turbo Manifold, Turbo Outlet pipe, Downpipe, 2 38mm tial wastegates, dump tubes. (everything ceramic coated black) $3200 shipped Precision 6466 T4 Divided 1.0 A/R Dual Ball Bearing Ceramic, polished inducer housing, ceramic coated exhaust housing. $1600 shipped Wiring Harness $400 shipped Rolling shell (with the rolling shell comes: custom tubular front end, HKS Coilovers, 1000hp axles, J30 diff(just put in), all adjustable arms, newly installed steering rack, Status Seat with rail, a knock off passenger seat with rail. $5000 Also have a lot of other parts I will be adding to this list! Do not ask me if I have parts other than what is posted, I will not reply. ALL PICTURES CAN BE FOUND HERE: https://drive.google.com/open?id=0Bw...UFyYndoSkI3TDQ Last edited by my240issex; 06-01-2017 at 03:36 PM.. |
Do you have the hand brake lever with cable and bracets?
Im adding the link to give you an idea of what i want. http://redirect.viglink.com/?format=...7-d454d147fded |
[QUOTE=fatduece;6195880]Do you have the hand brake lever with cable and bracets?
Im adding the link to give you an idea of what i If you read the post you would see I'm not selling other than what is already posted ONLY!!! |
It's first come first serve. If stuff sells cause you are unsure, don't have the money, or like to waste people's time, that's on you. Don't get upset towards me. Thanks. First person to send money for whatever item is posted will get it.
#17 | |
As you can imagine the machine shop is backed up like all hell as well. |
| fast, rb25, rb26, s14, schassis |
