Old 01-04-2008, 12:10 PM   #1
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
Safc + Stock Ka SETTINGS PLEASE!!!
I purchased an s14 with a stock ka(bone stock with intake and 3" exhaust). It came with a safc hooked up but the car has a very odd powerband for a ka. It just doesn't feel right.
Can anyone PLEASE give me a quick lesson on setting the vafc and what the setting should be for a stock ka?! I'm taking this car on a long trip tomorrow and would really like the proper/safe settings.
basically, i just want the computer to act as STOCK. I'm not looking for GAINS, i just 1. dont want to remove it at the moment(using it later), 2. don't want my car to blow up at the drift event
Thanks in advance for any advice/info.
ps- please dont tell me to take it off the car or flame the fact its on the car. Although its not ideal, it will be used to tune(if you want to call it that) my 7lbs boost set-up in the near future.
thanks
gotta240 is offline   Reply With Quote
Old 01-04-2008, 01:28 PM   #2
orion::S14
orion::S14's Avatar
orion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to behold
Does it have a hot-wire type setting to choose?
Seems to me, if it's in fact a V-AFC...then it won't work right on a MAF based motor.
Although, I admit...I've never tried.
You're best bet is to bypass it.
Find the MAF wire on the ECU that has been cut...take the AFC out of the loop, and reconnect the wire as stock.
- Brian
www.KA24DEvelopment.com
orion::S14 is offline   Reply With Quote
Old 01-04-2008, 01:39 PM   #3
gotta240
my bad, my title was correct but the description was wrong.
It is the apexi SAFC.
Old 01-04-2008, 01:41 PM   #4
johngriff
johngriff's Avatar
johngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfection
Send a message via AIM to johngriff
2 in 2 out.
0% across the board.
Or just disconnect and trash can it.
[email protected]
johngriff is offline   Reply With Quote
Old 01-04-2008, 01:43 PM   #5
specialk2003
specialk2003's Avatar
specialk2003 is a glorious beacon of lightspecialk2003 is a glorious beacon of lightspecialk2003 is a glorious beacon of lightspecialk2003 is a glorious beacon of lightspecialk2003 is a glorious beacon of lightspecialk2003 is a glorious beacon of lightspecialk2003 is a glorious beacon of lightspecialk2003 is a glorious beacon of lightspecialk2003 is a glorious beacon of lightspecialk2003 is a glorious beacon of lightspecialk2003 is a glorious beacon of light
Just put all the settings to 0%, on high and low throttle. That will be the easiest way to make it stok for now.
specialk2003 is offline   Reply With Quote
Old 01-04-2008, 02:01 PM   #6
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
- Brian
a vafc has the same type of settings as a safc
with added vtc control
and double the amount of tuning points
Just leave the vtc wires out and it will work just as a safc if you set it up correctly
(i used a vafc on my s14 )
I agree with orion:s14 , bypass it
importdude is offline   Reply With Quote
Old 01-04-2008, 02:36 PM   #7
gotta240
Thanks johngriff.
K. i got the 0s across the rpm range.
Where do i go to set the 2 in 2 out?
Old 01-04-2008, 02:43 PM   #8
johngriff
johngriff's Avatar
AFM type setup.
Should be ok if its already running.
[email protected]
Old 01-04-2008, 02:44 PM   #9
TRU_DAH-V
TRU_DAH-V's Avatar
TRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfection
you go to HOT WIRE there you can set it up as 2 in 2 out.
#/f/avatars/tru_dah-v.gif?type=sigpic&dateline=1234268839
TRU_DAH-V is offline   Reply With Quote
Old 01-04-2008, 05:26 PM   #10
gotta240
You guys rock. Thanks for just answering the question.
appriciated.
Old 01-05-2008, 02:53 AM   #11
gotta240
Ok, just went to check the HOT WIRE settings as suggested.
It WAS set at 5in 5out. I changed it to 2 in 2 out. Just trying to learn a little, so what exactly changed when it went from 5 to 2?
Old 01-05-2008, 03:16 AM   #12
240mph
240mph's Avatar
240mph is making a name for him/her self240mph is making a name for him/her self
Send a message via AIM to 240mph Send a message via MSN to 240mph
The hotwire sensor raises voltage as air flow increases, so the person who previously owned the car probably had a N60 maf to compensate voltage for higher air flow. You just set the voltage back to normal for the stock set-up.
240mph is offline   Reply With Quote
Old 01-05-2008, 02:00 PM   #13
johngriff
johngriff's Avatar
Those numbers represent the air flow meter calibration, since the afc sits inbetween the afm it replicates the signal to the ecu.
When selecting those numbers you are telling it that a type "2" air flow meter is coming in, and type 2 going out.
[email protected]
Old 01-13-2008, 09:45 AM   #14
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
in a vafc you get to choose the in and out. but you dont get to pick what kinda of sensor it is. im guessing its set at pressure sensor.
but ive seen ppl use it on there 240sx.
is it the same ne ways?
fS! vlsd ! slim fans ! hid kits ! lug nuts !
#/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 01-13-2008, 12:17 PM   #15
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
yeah but KA AFM are 5in and 5 out.
Review Thread
bardabe is offline   Reply With Quote
Old 01-26-2010, 01:14 PM   #16
ATXSR20
ATXSR20 is an unknown quantity at this point
I was curious, is there only one sensor setting that will allow the car to run good? I have heard so many differnet 2in 2out, 2 in 5out, 5in 5out, 5in 6out, 6in 5out, 6 in 6out, and I re initialized my safc and I HAD to set mine to 1 in and 6or7 out to get it to start and stay running. It drives ok but doesnt really feel like its running as good as stock. Everything else is 0'd out and I have a Z32 maf... I am gonna trash it, just waiting on meeting up with a buddy to pick up his stock sr maf. I was just curious about the safc and the sensor settings till then just want to make sure I am not screwing my car up untill then...
ATXSR20 is offline   Reply With Quote
Old 05-03-2012, 06:23 AM   #17
Crondy
Crondy's Avatar
Crondy is an unknown quantity at this point
found this, didn't want to make another thread. my car came with a de swap it's an s13 hatch, and the guy that i bought it from put a safc-2 in because it "wasn't running right" when he got it. how the hell could somebody think this pos will solve a problem?
Crondy is offline   Reply With Quote
Old 05-03-2012, 12:03 PM   #18
cotbu
cotbu's Avatar
I guess, it would be the same way you think, since you are looking for settings.
Old 05-03-2012, 02:11 PM   #19
Crondy
Crondy's Avatar
i didn't ask for settings i'm not looking for them and i already ripped it out. just wondering what type of problem could possibly be fixed by this pos. it's not running as well without the safc but sounds healthier if that makes any sense. i started diagnostics already but i was just kinda trying to get pointed in the right direction, i already have to go over almost everything.
Old 05-03-2012, 03:03 PM   #20
cotbu
cotbu's Avatar
I was just busting your balls!
Sent from my Highly Tuned Vibrant!!!
Old 05-04-2012, 11:21 AM   #21
Crondy
Crondy's Avatar
hahaha no hate no hate
