180sx Headlight Problem
Hello, Im having an issue with my right headlight where my low beam will not work.
My high beam works and both the high and low beam works on the left side. It is not a bulb as i have replaced it with multiple different bulbs and no luck. It's also not a fuse as all have been tested and work. Has anyone else had this problem? Thanks ![]() |
| 180sx |
