Competition Clutch and Flywheels at RedlineMotive!
![]() RedlineMotive is proud to carry the full line of Competition Clutch Kits and Competition Clutch Flywheels. Competition Clutch Kit Gravity Stage 1 Competition Clutch Kit Stage 2 Competition Clutch Kit Stage 3 Competition Clutch Kit Stage 4 Competition Clutch Kit Stage 5 Competition Clutch Lightweight Flywheel Stage 1 - Gravity Series 2400 Clutch Kit The economical solution for moderately modified cars or simply aggressive individuals with stock power. Offers 40-50% of torque capacity and maintains stock pedal feel. 300 mile break-in recommended with this set-up. DO NOT use with added forced induction such as turbo, supercharger, or NOS systems. The 2400 Series kit includes a Competition Clutch pressure plate, a 6 pad Carbotic high-torque performance disc assembly, all applicable bearings and the appropriate alignment tool. Stage 2 - Street Series 2100 Clutch Kit This assembly provides approximately 80% increase in torque capacity and is properly suited for aggressive street use and moderate track use. The Carbon Kevlar material with its alloy backing matched to a performance pressure plate will provide smooth engagement and extended life. 500 mile break-in highly recommended with this set-up. 300 mile break-in REQUIRED with this set-up. The 2100 Series kit includes a performance pressure plate, a high torque sprung disc with antiburst steel backed Carbon Kevlar facings, all applicable bearings, and the appropriate alignment tool. Stage 3 - Street/Strip Series 2300 Clutch Kit This segmented Kevlar material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly is suited for 150% increase in torque capacity. Provides quick but smooth engagement and extended life. 500 mile break-in REQUIRED with this set-up. The 2300 Series kit includes a performance pressure plate, a high torque sprung disc with segmented Kevlar facings, all applicable bearings, and the appropriate alignment tool. Stage 3 - IronMan Street/Strip Series 1680 Clutch Kit This assembly features our advanced hybrid iron and carbon friction material riveted to our high torque disc assembly in a six puck style. The IronMan provides outstanding stability, smooth engagement, and less wear on opposing surfaces. Offers 175% increase in torque capacity. 300 mile break-in recommended with this set-up. The 1680 Series kit includes a performance pressure plate, a six puck high torque sprung disc with Iron/Carbon buttons, all applicable bearings, and the appropriate alignment tool. Stage 4 - Strip Series 1620 Clutch Kit This assembly, available with a double spring, six rivet carriage is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides 250% increase in torque capacity. 300 mile break-in recommended with this set-up. The 1620 Series kit includes a performance pressure plate, a six puck high torque sprung disc with Ceramic buttons, all applicable bearings, and the appropriate alignment tool. Stage 4 - Strip Series 0620 Clutch Kit This assembly, available with a six puck rigid plate is good for penetrating engagement with higher horsepower applications. This disc complimented by a performance pressure plate provides 250% increase in torque capacity. 300 mile break-in recommended with this set-up. The 0620 Series kit includes a performance pressure plate, a six puck high torque rigid disc with Ceramic buttons, all applicable bearings, and the appropriate alignment tool. Stage 5 - Strip Series 1420 Clutch Kit This assembly, available with a double spring, six rivet carriage is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides 300% increase in torque capacity. 300 mile break-in recommended with this set-up. The 1420 Series kit includes a performance pressure plate, a four puck high torque sprung disc Ceramic buttons, all applicable bearings, and the appropriate alignment tool. Stage 5 - Strip Series 0420 Clutch Kit This assembly, available with a rigid plate is good for penetrating engagement with higher horsepower applications. This disc complimented by a performance pressure plate provides 300% increase in torque capacity. 300 mile break-in recommended with this set-up. The 0420 Series kit includes a performance pressure plate, a four puck high torque rigid disc with Ceramic buttons, all applicable bearings, and the appropriate alignment tool. |
