#31 |
![]() Join Date: Mar 2003
OK, I just did this with great results... I used Russell Fittings and Power-Flex Stainless Lines. Waiting to do the Resivor to Rack untill I get a new Resivor and possably a Cooler!
The Smaller Lines on the back side are 12x1.0 to 3AN... which I have yet to find!! -Drew |
#33 | |
#34 |
Bringing this back from the dead for great reason.
Makers Racing Power Steering Anti-Foaming Kit !! Looks like an Oil Filter attached to relocation block, but anyway... effective? and I take it this should be on the pressure side?!? I am litterally about to buy this with a Billion Power Steering Tank!! -Drew |
#35 |
![]() Join Date: May 2005
I was thinking about gettin this to start my ps cooler setup
KRC High Volume Power Steering Pump Kit - SR20DET [ 20005000/91510 000 ] - Enjuku Racing - Performance Parts and High Quality Fabrication |
#36 |
![]() Join Date: Jan 2006
i did a canton racing alumn PS res along with braided line and AN fittings with a -6 ps cooler from summit. I have the KRC PS pump pictured above also. it is so much better to make your own cooler kit VS buying pre made kits(CB).
#37 |
![]() Join Date: Mar 2004
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
The only thing I hate about the whole AN setup for p/s is the damn hose ends... no one makes steel ends in black, and you're not supposed to use the aluminum ones on the high pressure lines. Don't want chrome or that red/blue either. But oh well. Nice set-up, regardless.
#38 |
wonder if it is ok to use the pump -6 male alumn fitting and high pressure rack alumn -6 an fitting with steel female hose ends...seems thats what the orignal poster did.
#39 |
I think the fittings are fine for whatever reason, but the hose ends aren't. I guess something to do with the pressure needed to keep the hose from slipping would gall the aluminum? Someone more experienced with the concept might know. I was just told "No." by the parts guy. The steel ends were cheaper too, so he wasn't just trying to get extra coin.
#40 | |
![]() Join Date: Nov 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
the reason for the steel ends if bc the high pressure hose is differnt from typical braided SS hose. been running this set-up in a buddys car for quite some time w/o any issues.
#41 |
![]() Join Date: Jun 2011
What sized AN is on the return hose on the rack side when the hose is about to go up to the reservoir from the rack?
Also, anyone know what the best hose clamps are, there's so many options, looking for screw tightened I think |
#42 | |
OP, thanks for making this thread, it was extremely useful when I was buying my AN lines for my PS setup. Owe you one bro. |
#46 |
![]() Join Date: Mar 2010
Trader Rating: (34)
![]() Feedback Score: 34 reviews
+1!!
Good write up, im currently changing almost everything to an lines. How much PSI do you think the PS hoses run? Im using BMRS lines throughout already but their line up only has hoses rated to 500psi Also more pics with the cooler installed and lines to the rack?? |
#47 |
So I went with the op's setup and now my line is leaking at the high pressure fitting going into the rack. Anyone have a solution to this? Its leaking more specifically at the 14mm to -6 adapter, I think its leaking because the threads are so short, only threads in half of what the original hard line there does. Anyone know what I can do to get it to stop leaking?
#48 | |
Also make sure that there isn't any pressure being exerted on the fitting, your line shouldn't pull or by tight at all. Try rearranging the geometry of your angled fittings to adjust this just my 2cents |
#49 |
good suggestion, Ill give it a go, but I went ahead and ordered a 3/8 to -6 adapter just in case, its only 5 bucks from jegs. If the readjusting doesnt work Im going to just put the hardline portion back into the rack, cut the end off and throw on the adapter to -6.
EDIT: crap just realized those fittings are only good to 50psi, the hose sees way more than that I assume... |
#50 |
Since the ps line on a stock s13 goes
RACK-->Hardline-->soft PS hose with sensor-->PS pump Could I just put the stock hardline back in, convert from hardline to -6 with this and be good to go? (it says its for fuel system only...) Earl's 9894DBH Earl's Fuel Injection Female O-Ring Seals That fucking fitting is leaking like a stuck pig, and I dont want to torque it down any harder, Im afraid of stipping the threads. Tried the teflon tape and readjusting the fitting with no luck. The real problem is that the fitting is so short it only threads in half of what the original hardline did, doesn't seal against the tapered inside of the rack. Shoulda just bought a fucking premade line from chasebays or something. ![]() |
#51 |
im confused where the part for "Earl's Fuel Injection Female O-Ring Seals" came from in this article
try this Earl's 991954 Earl's AN to Metric Adapters looks somewhat different than what you are using, if you need the male to female fitting i am sure that earls makes one for the same thread pitch and AN size Did you use the crush washer in the correct place? I believe it is between the high pressure fitting into the rack If you dont have enough threads then you need a different fitting, end of story. Make sure that the next fitting you get has enough threading, and make sure that it looks like what the OP used before you buy it |
#52 | |
Yeah I think you are a little confused. I went with the OP identical setup (except the stuff for the reservoir). So everything for the high pressure side is just like the OP's. Im lookin at the pictures of the op's setup and I dont see any washers for the rack side but I guess I can try that. The washer I have goes between the pump and the line.. And the link I listed is for an adapter from the factory hardline coming out of the rack to AN, if you reread my last post you'll see why I listed it. |
#53 |
Does anyone have any more feedback about the sloppiness feel? I know Codyace had said his was fine, so I'm curious as to what the other dude a year or so ago did to make his steering response feel like shit.
#54 | ||
Also, leaks will result in a sloppy feeling as there are varying pressures assisting your turning of the wheel. My steering was sloppy at one point because the steering column wasn't connected to the rack as tightly as it could have been ![]() |
#55 |
![]() Join Date: Apr 2003
I have run into a few racks that leak using the earls fitting. My solution was to put another earls or other brand part to seal. They are called STAT O Seals. They are aluminum washers with a bonded rubber o ring on the ID of the washer. they are used to seal where crusher washer wont quite work.
http://www.forcedfabllc.com/ |
#56 |
![]() Join Date: Nov 2008
Anyone using the Chase Bays kit? I've had it sitting here for about 6 months but had too many other projects going on to install it. It doesn't come with a cooler but it would be very simple to add one...
Chase Bays Power Steering Kit for Nissan 240sx - Nissan 240sx - ChaseBays.com
#57 | |||
250 bones for THAT? Looks like he's probably making at least 50% profit. |
#59 |
ill be honest, this is my first go at working with AN stuff and not very impressed with my setup currently. Maybe it has to do with inexperience but as far as high pressure stuff goes, the steel fittings for the highpressure line could easily loosen over time, I mean after torquing it down, with a little bit of pressure I could still rotate the steel fitting off the earls fitting (where it meets the pump).
I ended up using a liquid gel sealent to get the lines to stop leaking. My recommendation..go with something premade thats got nice crimped on fittings...especially for something thats high pressure, no chance of it coming apart from vibrations or a accidental bump. |
#60 | |
For anyone having sealing problems with the high pressure rack fitting the issues seems to be with the Earls adapter fittings being too short and the o-ring not seating in the rack. A couple other companies sell longer fittings.
#/f/tech-talk/201523...s-leaking.html
S12 || KN13 || S13 || B16 |
