Old 01-28-2009, 03:57 PM   #1
redsx13
redsx13's Avatar
redsx13 is an unknown quantity at this point
HELP!, SR is undriveable My A/F ratio is all over the place!!*****Got VIDEOS!***
Like the post says, SR runs horribly, This issue renders my car undriveable and I have been dealing with this issue for over a year, I have spent thousands and thousands of dollars trying to fix it with no luck at all. I am just about ready to push this thing off of a cliff.
The videos i have are at 2000 and 3000 rpms, but car will act like this at all rpms, there is just no need to take that many videos. (note: i am holding the rpms very very steady, the tach is fixed at 2 and 3 thousand, motor is not revving)
2000 rpms (exactly)
http://s279.photobucket.com/al...4.flv
3000 rpms (exactly)
http://s279.photobucket.com/al...5.flv
Idle (if you notice, it takes a longggg time for the car to make it back to 14)
http://s279.photobucket.com/al...7.flv
redsx13 is offline   Reply With Quote
Old 01-28-2009, 04:18 PM   #2
slider2828
slider2828's Avatar
Do I get thousands and thousands of dollars to fix it?
Turn and Burn!
Old 01-28-2009, 04:20 PM   #3
slider2828
slider2828's Avatar
you have vacuum leak and check for that....
you have a shitty mass airflow sensor....
you have an intake leak....
Check for those things in that order...
Turn and Burn!
Old 01-28-2009, 05:32 PM   #4
redsx13
redsx13's Avatar
- Just did a boost leak test (how do i check for a vacuum leak?)
- Not my maf or maf wires
- no intake leak
Old 01-28-2009, 05:35 PM   #5
slider2828
slider2828's Avatar
Not that many vacuum hoses... Pull and check each one....
Did you swap mafs? to find out?
Turn and Burn!
Old 01-29-2009, 12:21 AM   #6
redsx13
redsx13's Avatar
all the vacuum hoses are brand new.but i double checked anyway. all good
yes i swapped mafs (works for sure), and ran new wires.
Old 01-29-2009, 12:26 AM   #7
Slideways^Jordan
Slideways^Jordan's Avatar
Slideways^Jordan is an unknown quantity at this point
Send a message via AIM to Slideways^Jordan Send a message via Yahoo to Slideways^Jordan
you need a new tune! if you have a tune and check the gap on your spark plugs!
Slideways^Jordan is offline   Reply With Quote
Old 01-29-2009, 12:45 AM   #8
redsx13
redsx13's Avatar
Sparkplugs and gaps are good, coil packs and coil pack harness is also good
I brought it to a tuning shop for a tune but they couldn't fix the problem. They had it for over a week and still couldn't get it to run properly. They checked almost every major component; they also threw a power fc on it to tune it with, but no luck at all. (1. this was before I got the A/F gauge so they could not see exactly what was going on mixture wise. 2. For the tune, they just messed with it at idle, they never dyno'd it.)
You would think that if it just needed a tune, it would either be rich or lean, not fluctuate like that. Do you really think it sounds like a tune issue? Personal experience?
Old 01-29-2009, 07:29 AM   #9
Erjay1
Erjay1's Avatar
Erjay1 is making a name for him/her selfErjay1 is making a name for him/her self
So what shld your a/f be at idle???
Erjay1 is offline   Reply With Quote
Old 01-29-2009, 08:56 AM   #10
Sileighty_85
Sileighty_85's Avatar
Maybe have a Vac leak After the MAF
The turbo's Stock Rubber intake pipe has a hole in it for the Crank case/Valve cover breather line.
Make sure it pluged
on a side note sounds like your timing chain is loose or you lifters need to be blead bad
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-29-2009, 12:43 PM   #11
redsx13
redsx13's Avatar
like 14. something 10 is really really rich.
Make sure it pluged
No boost leaks at all
My timing chain does seem a little loose, but the sound you hear is the dash, steering column, and gauges rattling. The car runs really rough. solid motormounts dont help either.
Old 01-29-2009, 01:07 PM   #12
Sileighty_85
If your chain is loose you might have jumped a tooth on the gears
Check mechaincal timing
後輪駆動車1番
1986 SR86 - 200ish
Old 01-29-2009, 03:00 PM   #13
slider2828
slider2828's Avatar
Hmmm I dunno about timing, but its worth while to check... But if timing was off it would sound a lot worse then that, but easy enough and worth the check.
What does your spark plugs look like when you pull it out? Stick dark? White? Oily?
Turn and Burn!
Old 01-29-2009, 03:30 PM   #14
simplistek
simplistek is an unknown quantity at this point
usually if the car is cruising the car goes into a closed loop cycle between 14 and 15 AFR. this allows the engine to save gas and keep the engine from blowing. it looks like your car is doing the same thing but while under no load. when you say it runs horribly, can you not pass a certain RPM? or the car doesnt have power at all?
v e r t e x - u s a . c o m
simplistek is offline   Reply With Quote
Old 01-29-2009, 07:33 PM   #15
redsx13
redsx13's Avatar
i checked it on the cam gears, whit marks on chain line up with dots on gears. couldn't see the one on the drive gear though.
Old 01-29-2009, 07:42 PM   #16
redsx13
redsx13's Avatar
no, it will rev all the way up, it seems to lack power and only boost about 4-5 psi. Very rough, The idle also searches up and down (at most 100 rpms)
do i need to take another video of the car driving at 300 rpms?
Old 01-31-2009, 06:53 PM   #17
sdrmiami
sdrmiami's Avatar
sdrmiami is an unknown quantity at this point
Send a message via MSN to sdrmiami
what ecu are you running? what afm you running? what pump? whats your Vacume @ on idel? email me your reply. [email protected] i would not be driving the car like that..
sdrmiami is offline   Reply With Quote
Old 01-31-2009, 07:27 PM   #18
Sileighty_85
Set Crank at TDC
you should have silver links that line up on the dots
(you will have to rotate the crank abit to get them to line up properly)
If not pay attention to the #1 Cylinder Cam lobes they will face outward
then check the CAS Line up marks should be on the left dot
You wont be able to check the Cranks line up dots unless you pull the oil pump off
後輪駆動車1番
1986 SR86 - 200ish
Old 01-31-2009, 08:12 PM   #19
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
UNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond repute
Feedback Score: 40 reviews
Send a message via AIM to UNISA JECS
You dont mention yoru setup at all, but my guess is you got a stock ECU perhaps and probably running a WALBRO 255? Tell us your setup?
UNISA JECS is offline   Reply With Quote
Old 02-01-2009, 11:27 PM   #20
redsx13
redsx13's Avatar
I didn't want to mention my setup because i was afraid it would skew the responces would get, i didn't want people to think it was the aftermarket parts causing the problem.
-The car origanally had 440cc injectors, z32 maf, and ecu tune. thats how i got it from japan in a clip. (It ran the same as it does now.)
-Downgraded to stock everything, (Runs the same as it does now, didn't fix the problem )
-shop told me they could fix the problem If i buy a PFC and tune the car, here is the setup now...
-Power FC D-Jetro
-No MAF
-Back to 440cc injectors
-walbro fuel pump
(P.S., shop was wrong, they tuned the car and i didn't fix anything!)
Old 02-02-2009, 10:38 AM   #21
ANVIL
ANVIL's Avatar
ANVIL can only hope to improve
i wonder if they adjusted the PFC for the upgraded injectors. check that maybe
ANVIL is offline   Reply With Quote
Old 02-04-2009, 03:59 PM   #22
redsx13
redsx13's Avatar
no, like i said in the post, it had the same problem all stock.
Old 02-14-2009, 08:43 PM   #23
d-magic
d-magic is an unknown quantity at this point
it sounds like you have a vacuum leak. try hook up at the manifold.
d-magic is offline   Reply With Quote
Old 02-25-2009, 06:58 PM   #24
JeremyR
JeremyR's Avatar
JeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the rough
Send a message via AIM to JeremyR
did you check your fuel lines for a leak?
did you check your fuel pressure?
bad 02 sensor maybe? i dont think this is it either though.
doesnt seem to be a vacuum leak to me.
you say it ran the same on a map setup as it did on a maf setup. so that rules out alot. problem is most likely fuel related/mechanical related. you say the timing is set on everything so that should rule out mechanical shit. i would re-check the fuel system, this includes the ignition (spark) system as well. personally, i think that maybe your fuel pressure is too high, causing a rich condition, or your injectors are bad, causing a rich condition. send in your injectors to be cleaned, and tested. buy a new fpr. check all fuel lines. double check that your walbro is in good shape as well. maybe change the plugs again for shits and giggles. you say the plugs are fine, but really if your a/f ratios are this fucked than you would see some signs on the plugs...
drive your car into the garbage and leave it there
JeremyR is offline   Reply With Quote
Old 02-25-2009, 11:28 PM   #25
redsx13
redsx13's Avatar
1. no leak in the fuel lines
2.checked fuel pressure+replaced regulator([email protected] idle, 43.5 w/vac disconnect)
3.never checked the 02(when i unplug it the car runs richer but better[doesnt misfire as much]) wtf?
4.replaced injectors
5. plugs look a little white-ish but all consistent and not that bad.
the car idles strange too, it searches up and down from 800 to 900. and misfires at idle. the miss is inconsistent though, sometimes it misses every 2-3 seconds, sometimes it just keeps missing (around 1 second apart)
Old 02-26-2009, 09:25 AM   #26
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
How many wires does your 02 sensor have? With most A/F guages they won't read right unless you upgrade to the 5 wire sensor. Did you check the fuel filter? You are running lean and should def. not drive the car much. I'm not 100% with fuel pressures but 40psi sounds alittle low. Most ppl i know run atleast 60psi.
godsmack is offline   Reply With Quote
Old 02-26-2009, 08:31 PM   #27
Jus Skott
Jus Skott's Avatar
Jus Skott can only hope to improveJus Skott can only hope to improve
Send a message via AIM to Jus Skott
OH shit son. your white! lol.
just wondering how long has that wide band been in car?
Looking for yard parts, PM me.
Jus Skott is offline   Reply With Quote
Old 02-26-2009, 09:30 PM   #28
Sileighty_85
Stock F/P is 43 psi
後輪駆動車1番
1986 SR86 - 200ish
Old 03-01-2009, 11:10 AM   #29
blackej7
blackej7's Avatar
blackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really nice
Maybe theres something mechanically wrong.
have you done a compression/leakdown test?
Cant you monitor data with the power fc? check all your values, make sure everything is normal.
blackej7 is offline   Reply With Quote
Old 03-01-2009, 09:49 PM   #30
redsx13
redsx13's Avatar
i have a wideband
