#32 |
![]() Join Date: Jun 2004
Trader Rating: (73)
I used this thread for my wheel, even though I have an S13. Old threads are for this EXACTLY
(At least the useful ones.)
#34 |
![]() Join Date: Jul 2003
Do you get the fact that this is a How To Thread? So I'm updating it by providing additional info so that I won't need to create another incase someone does a search. If you read the thread you would realize that I had this exact same question as to the resistor when the thread was originally create. Have a good day.
-Ren |
#35 |
what about if you have cruise control buttons? I was thinkin about getting a steering wheel but what about all my buttons? I still want cruise control...Can I rid it so that my buttons are somewhere else??
Tony |
#36 |
now i can get my horn to work, thanks!
www.illgarage.com |
#37 | |
Trader Rating: (73)
#38 |
Just to add to this:
When I need odd tools I tend to look to Harbor Freight since you can often get a set of something for the cost of 1 from Sears, Snap-On, etc. Frankly, if you only use it once or twice, it doesn't matter if its super high quality. So, I checked out HF's site and they have a 100 piece security bit set that's normally $15, on sale for $6 now (haha, I love you HF). Unfortunately, when I finally dug up the specs, it only goes to T-40 Security Torx, and T-45 regular. Works Bell hubs do come with the T-50 key, so you don't have to worry about it with them (or the HKB). Moral of the story: get a decent hub, not some shitty Momo, and save yourself some hassle and the annoyance of having to track down a weird tool! |
#41 | |
![]() Join Date: Mar 2005
Also, for those who purchase a S13 hub from me (#602 or short is #618S), it requires that you hammered in the included prongs into the back of the hub. It should go in the 12 o clock and 6 o clock position in order to cancel your turn signals. S14 does not require this.
A SPEC PRODUCTS CORP AME Wheels, Advan, ARC, Gram Lights, Nardi, Personal, Recaro, Works Bell, Work Wheels, Volk Racing, 5Zigen, & more! 626.618.1100 x 103 / aim: aspectuan Advertiser's Specials! Read / Give Feedback! Please Rate Us!
#42 |
![]() Join Date: Mar 2007
Sorry to bump an old thread.. but its better than making a new one =]
I got a quick question though. I have the NRG hub adapter, and i need to know what to do with this piece Do i ditch this, and just throw the actual hub adapter on? |
#45 |
sorry to wake up an old thread, but how do you put in the resistor? I don't have a prefabricated resistor like optionzero shown. I have just the regular resistor that you see at hardware store, look like this ---[ ]--- so how do I use it to cancel the SRS and still let the passenger side work. Thanks
#46 |
4bangers - well cant u just bend the wires to be parallel?
to the rest of ya who care - i found on an older thread the late 90's sentra clockspring is cheaper AND compatible. bought it for my 240, hope it works! |
#51 |
![]() Join Date: Sep 2006
Changing steering wheels
How tight should I get the 19mm nut that holds the new hub on to the column?
Also here is a photo of how I used a wheel puller I borrowed from Autozone--$15 deposit. ![]() Last edited by miklos; 07-27-2008 at 02:50 AM.. |
#52 |
![]() Join Date: Feb 2007
i would like to add that momo does make an s14 specific hub and it does come with the signal cancelation. and then it's a simple pressure contact on the back side to get the horn to work. got mine done in 1 hour.
so right now i'm using a momo hub with nrg short QR and a momo wheel and still retain all function EXCEPT passenger airbags. but really who cares about the passengers anyways. |
