Old 05-21-2008, 10:35 PM   #1
tercel drifter
tercel drifter is an unknown quantity at this point
Vacum line help
Well I've added a fmic and I need help with some vacum just to double check if i got everything right.
This is for reference i found it at http://forums.nicoclub.com/zerothread?id=305170.
Well i bought the car already swapped so it look like i'm missing the EAI control valve, the EAI control solenoid and the boost pressure solenoid because i did not have any of those lines running like that.
Now lets look at the first pic :roll:
Now is this right if i have the line from the wastegate go to the line beside throttle body. Is this how you hook up a BOV?
Is it alright if i plug this one up, my friends 180's is plugged up.
Now i think this is the reciculatory system i dont think i'll keep it because it will just add more vacum line headaches. Can i put my bov at this spot? If not what's the best way to cap it off?
Now for the finale!
Since i won't be using the recirculation valve i can just cap that hole off, what's the easiest way?
Thanks for your patience,!!
Alex
tercel drifter is offline   Reply With Quote
Old 05-21-2008, 11:45 PM   #2
slider2828
slider2828's Avatar
You need a boost controller.... You eliminated the thing that drives the wastegate... Your system is useless... no matter what you do....
What happened to all the stock stuff connected to the waste on the turbo?
Turn and Burn!
Old 05-22-2008, 12:13 AM   #3
dino6192
dino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond reputedino6192 has a reputation beyond repute
1. hook up your charcoal canister line! thats letting fumes straight from your gas tank. and why are you hooking up 2 BOV's? you dont need that one from the sidemount if you have that greddy!
dino6192 is offline   Reply With Quote
Old 05-22-2008, 12:28 AM   #4
slider2828
slider2828's Avatar
nah... charcoal canister is useless...
Most people remove the whole set up...
Turn and Burn!
Old 05-22-2008, 10:39 AM   #5
deuceforty
deuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of light
so let me get this straight, your running your boost gauge on your wastegate line, which is connected under the throttle body?
so your wastegate is seeing your manifold pressure.. if it was me i would get a nipple welded onto the compressor outlet so you have the shortest wastegate line possible.
connect the BOV to the line under the throttle body.
charcoal cannister you can eliminate
there isnt really a best way to cap off the old recirc hole, do whatever will work and not leak
TWO TONE COUPE FS NC
deuceforty is offline   Reply With Quote
Old 10-08-2008, 11:58 AM   #6
jonathan12uiz
jonathan12uiz is an unknown quantity at this point
Send a message via AIM to jonathan12uiz Send a message via MSN to jonathan12uiz Send a message via Yahoo to jonathan12uiz
I don't know if you fixed this yet, but here is how you NEED to do this.
There are 3 nipples on the throttle body. 2 on the top and 1 on the bottom.
- Cap off the bottom one, you don't need it.
- The top left (which is the smaller diameter one) goes to the fuel pressure regulator. This is also the same line that you can tee into for a boost/vac gauge.
- The top right (which is the LARGER diameter one) is connected directly to your BOV.
You are probably wondering why I didn't tell you to connect your wastegate to any of those lines. The reason is because YOU DON'T TEE YOUR WASTEGATE TO YOUR BOV!
Go to home depot or lowes and buy a threaded brass nipple with the same size as your vacuum lines.
Take your hotpipe off and drill a hole matching the diameter of the threaded end of the brass nipple.
TAP the hole using a pipe thread size tap. (you can get these at auto part stores)
Wrap the threaded end of the brass nipple with teflon tape
and last... thread it into your hotpipe and run a vac line as short as possible to your wastegate and BAM you are done.
Note. the bottom vac nipple on the throttle body could go to the charcoal canister, BUT you don't need that useless thing. just take it out like i did and save some weight. LOL!
jonathan12uiz is offline   Reply With Quote
