Old 01-02-2009, 02:09 PM   #1
93nismo
93nismo's Avatar
93nismo is an unknown quantity at this point
s13 o/d light flashing
ive got a 93 240 hatch and i went to go home from work today and noticed the overdrive light was flashing. its snowed lately but i dont drive it unless the roads are clear so i dont think thats got anything to do with it. any ideas on why and how to fix it?
thanks
93nismo is offline   Reply With Quote
Old 01-02-2009, 02:29 PM   #2
Ceepo
Ceepo's Avatar
Ceepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enough
my s14 does that sometimes, i press the od button and then press it again and it stops lol... idk im sure thats not a fix but works for me, i swapping it soon anywho...
TW: #/f/cars-sale/390459...d9s-coils.html
Ceepo is offline   Reply With Quote
Old 01-02-2009, 02:35 PM   #3
93nismo
93nismo's Avatar
i dotn think mines a button tho. it just flashes. it dosent really bother me. i was just wondering if any1 else had the same prob
Old 01-02-2009, 02:39 PM   #4
smelly240
smelly240's Avatar
smelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfection
nope - that means theres a transmission fault... looks like you might have a problem either beginning or already there... if you get it more - get it on a consult or somethin.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
smelly240 is offline   Reply With Quote
Old 01-02-2009, 03:33 PM   #5
blackrms13
blackrms13's Avatar
blackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfection
Send a message via AIM to blackrms13
u have a auto or manual?
91' 240sx Fastback LE
blackrms13 is offline   Reply With Quote
Old 01-02-2009, 05:14 PM   #6
93nismo
93nismo's Avatar
its a manual 5 speed. it makes the kicking up sand noise in about all the gears tho...
Old 01-02-2009, 05:18 PM   #7
93nismo
93nismo's Avatar
u think maybe if i flushed the trans it would help? high school budget kinda means little or no money all the time
Old 01-02-2009, 06:08 PM   #8
projectRDM
projectRDM's Avatar
If it's a manual, why do you even have an O/D light?
The O/D light flashing signals a transmission fault, an AUTO transmission fault. There's a breakdown of the codes in the FSM. Which is pointless if you don't have an auto.
FORMERLY R240NA
Old 01-02-2009, 07:02 PM   #9
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
sounds like an auto>manual swap.
mine does same thing but only on startups.
stops blinking after a couple seconds
lexus baby
5t341tH is offline   Reply With Quote
Old 01-02-2009, 07:17 PM   #10
93nismo
93nismo's Avatar
i bought it as a auto>manual swap. and it only does it at startup for a few seconds. think i should worry about it?
Old 01-02-2009, 07:26 PM   #11
5t341tH
5t341tH's Avatar
nah. ur probably using an auto ecu in ur car. its all good. iirc, it gives u no rev limit/speed limit
if ur worried about it, take out the light bulb
lexus baby
Old 01-02-2009, 07:42 PM   #12
93nismo
93nismo's Avatar
sweet deal. its the last thing i need lol. i went from a Z with a hole about the size of my arm to this. id hate to have to spend an obnoxious amount just to get it working... lol thanks guys
Old 01-03-2009, 09:04 AM   #13
projectRDM
projectRDM's Avatar
Why? You obviously no longer have an auto in the car. That's like asking if you should worry about a low washer fluid light when you don't even have the washer bottle anymore.
FORMERLY R240NA
Old 01-03-2009, 10:34 AM   #14
93nismo
93nismo's Avatar
it was explained. im not now. like i said, im learnin as i go. i dont know a whole lot as of right now. thanks again for the help tho
Old 01-05-2009, 03:16 AM   #15
TheXFlames
TheXFlames's Avatar
TheXFlames is an unknown quantity at this point
Send a message via AIM to TheXFlames Send a message via Yahoo to TheXFlames
s13
hahaha so typical...
thank to no low washer fluid lights in my chuki
TheXFlames is offline   Reply With Quote
