Old 10-30-2009, 08:22 PM   #1
jspec240
jspec240's Avatar
jspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfection
Thumbs up Parts Compatability Thread (OEM upgrades) Full Spectrum
Compatibility thread... There are a lot of spread out threads of parts that will fit on on different chassis so I think this would be a good Idea to put em all on one thread. Its also here to help save money or make some on the forums. I know there will be
Please note any modifications needed if they are light or if there is a conversion and who makes it.
This is not Just for 240's its for any S and Z chassis, datsun as well as Infinity OEM compatable parts to and from them all.
Im also going to add Links for how too's and precise info. Heres a couple popular ones
The best s13/s14 300zx brake upgrade thread ever!!
The Definitive 300ZX Brake Swap!
VLSD Info for 240s
1. KA24DEvelopment.com :: VLSD Swap Information
2. 300ZX N/A (Z32) 4.083 ratio final drive swap (for a q45 upgrade)
3. Install Guide: Q45 Differential swap into 240SX subframe [Archive] - FreshAlloy.com Forums Q45 Diff info
Heres a list of what I know will fit on S13 and S14's, some are for KA turbo. A lot are well known but Id like to get the full spectrum.
Heres what I have gathered....
All contributors will have their screen name attached to this updated page...
(Duffman)
Z31 Turbo (non SS model) clutch type +4/87: works with open diff output flanges. Use S13 case and cover
(Bushido) Z31 Pad carrier for rear s13 calipers
300zx 90-96 N/A to s13/s14/s15/y32/y33
Calipers 26mm Aluminum (90 only) 91 & 92.5 early N/A and TT 30mm Aluminium, late 92.5-96 30mm iron both NA and TT - brake lines needed
rotors
MAF N62
BMC
Brake booster
Rear N/A Hubs
Rear aluminum uprights
Diff N/A has 4.08 gears can be used with pre 1/94 j30 or OEM 180sx axles
wheels
Ebrake assy coupled with R33 Brake lines (must have z32, or s14 5 lug rear hubs)
Transmission with Mazworks adapter plate
Z32 90 - 96 tt
injectors (370cc) purples
Calipers 26mm Aluminum (90 only) 91-96 30mm aluminium - brake lines needed
rotors
MAF N62
BMC
Brake booster
Rear Hubs
Diff 3.9
wheels
y32 Q45 to s13/s14/sr20det vvt and non
Throttle body
370cc injectors (purples) only on the 94's
Ignitor chips
calipers
rotors
Rear hubs
Differential 3.54 gears need to change axles or output flanges for 6 bolt
for the 5 bolt j30 axles will fit in to the s13
Rear struts
y33 q45 97-01 to s13/s14
Calipers
Rotors
Rear hubs
Diff
Ignitors
Rear struts
Y34 q45 01-06 to s13/s14
calipers
rotors
Diff
Rear struts
Rear hubs
J30 to s13/s14
(Z28ricer) Front J30 5 lug hubs can be drilled out to fit OEM S13 bearings
Rear hubs/axles/and diff (need all to work)
z33 to s13/s14
Brembo brakes with an adapter
rotors
z34 to s13/s14
(Duffman)R34 torsen, GT-R non V-spec: unknown but I assume its 31mm 30 spline
brakes
rotors
wheels
r32 to s13/14/15
(Duffman) R32 and R33 GT-R only, non V-Spec clutch type: uses 31mm 30 spline output shafts. 3 out of 6 bolts line up (sort of) when using skyline output shafts or R230v output shafts (Q45 and turbo Z32).
calipers
rotors
seats
Eagle talon turbo 89-98
440cc Injectors (direct bolt in to for KA-T or S20DET)
rx7 FD to S13/S14
210 LPH fuel pump
Injectors but primary and secondary are different sizes
Supra - s13/s14
440 injectors will fit with a resistor pack and top feed rail
Sentra /SE-R spec-v to s13/s14
(EEK) Brembo calipers
(SWAYRAY) you'll need a 1mm spacer/washer to center the caliper w/ pads onto the rotor.... those spec-v rotors are very similar to the R33 GT-R w/ brembos only painted gold rather than black
(Stinky 180)the early 90s sentra ball joints are interchangeable
Maxima - s13
(Bushido) Rotors
(stinky_180) 90s maxima key ring light -> s13 (2 wires
S13 to s14/15
s14/15 Seats
s14/s15 Brakes
s14 KA Engine/tranny swaps over with minor mods
(EEK)s14/15 can use the s13 coilovers but must drill out the knuckle (Jspec240) must change the tops of the rear coilovers to the s13's
S15 SR swap Requires Drive line and diff if you want your speedo working
S15 Mirrors
s15 Steering wheel
S14 to s13 s15
s13 /s15 Seats front and rear
s13 Seat belts from both will work as manual belts
s13 Lower Control Arms are 15mm longer from s14
s14/s15 5 lug hubs ( need front spindles for s13 )
s15 rear seats
S15 to s13/14
s13 The s14 vlsd will fit with a quick change of the cover.
s15 SR swaps to both easily as dose the others however requires drive line and differential has the speedo instead of in the tranny.
s13/s14 Seats front and rear
This is off the top of my head. As posts are made (let me know if Im wrong as well) I will keep the info up to date on this first post so we wont have to search for them.
This was a short example so please if you know of any OEM part upgrades from other cars... POST EM UP
More to come
DREW
SLIDE TO SIDE WORLD WIDE
Feedback!! #/f/showthread.php?t=182673
661 sliders Gymkhana @ buttonwillow
#/f/south-western-st...-sessions.html
>> Bakersfield Hook up thread <<
jspec240 is offline   Reply With Quote
Old 10-31-2009, 12:29 AM   #2
Devens240
Devens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really nice
a few of those aren't bolt in per say, such as Z33 seats. you have to make custom mounts.
Devens240 is offline   Reply With Quote
Old 10-31-2009, 12:34 AM   #3
I LUV MY S13
I LUV MY S13's Avatar
Trader Rating: (35)
Feedback Score: 35 reviews
nice....got a NICO thing goin on here
-Jorge
Old 10-31-2009, 03:00 AM   #4
eek
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Z33 brakes do NOT need any type of adapter. You need to re-drill the holes to accept the larger 14mm thickness bolts. Other than that, its a bolt on affair. Skyline r33/r32 gtr brembos and non brembos are also DIRECT bolt on.
You might want to add so are the Sentra SE-R spec-v brembos are bolt on esp for 4-lug cars unless you want to re-drill the rotors for 5-lug.
S14/S15 suspension is interchangeable. S13/S14 fronts shocks/springs will work on either car, with the exception of the larger bolts needed or re-drilling the shock mounting holes to the front knuckle.
All front seats from any s13/s14/s15 are a direct bolt in. S14/S15 rear seats are interchangeable.
That's all that pops up in my head, There is way too much to list. Hence the SEARCH feature is VERY useful.
eek is offline   Reply With Quote
Old 11-01-2009, 12:31 AM   #5
jspec240
jspec240's Avatar
Ok z33 seats arent interchangable what else wasnt correct. LMK
Thanks
Instead of being sarcastic, why dont you spell it out a little more. Its gettin old when some one is trying to help others out and people want to hate. elaborate....or keep your shannanagans to your lonesome...
Thank you for the info and as promised it is posted in the first post. This is the reason Im starting this thread because there is way too many upgrades to list and Id like to know every one hence the creation of this thread so if you got more throw em down...
Keep the positive tech info commin it will control inept posts/threads
DREW
Old 11-01-2009, 01:55 AM   #6
Z28ricer
Z28ricer is an unknown quantity at this point
Not sure if it was mentioned but J30 hubs can have the wheel bearings pressed out, S13 bearings pressed in, to be correct the groove for the lock retaining ring needs to be re-machined to a different spot due to the S13 bearing being a little wider.
This allows for a hub that bolts right on the S13 spindle, while using OEM parts.
Z28ricer is offline   Reply With Quote
Old 11-01-2009, 01:07 AM   #7
jspec240
jspec240's Avatar
front/rear or both?? good info tho cause I can get two sets now
DREW
Old 11-01-2009, 01:41 AM   #8
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
wangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfection
Feedback Score: 36 reviews
Send a message via AIM to wangan_cruiser
if you dont have any valuable information GTFO.
wangan_cruiser is offline   Reply With Quote
Old 11-01-2009, 01:45 AM   #9
jspec240
jspec240's Avatar
^^^ Thank you sir... I think I just collaborated a lot of spread out threads into one for easier searching. last thing we need is haters.
we need more like you bro.....
DREW
Old 11-02-2009, 01:08 AM   #10
Z28ricer
Heres a shot of the J30 hub done for S13 install, iirc the groove for the snap ring needed to be moved toward the inner edge of the hub by .195"
Old 11-02-2009, 01:12 AM   #11
Slideways^Jordan
Slideways^Jordan's Avatar
Slideways^Jordan is an unknown quantity at this point
Send a message via AIM to Slideways^Jordan Send a message via Yahoo to Slideways^Jordan
So i take it these 5 lug hubs will now fit on an s13 Correct. So the j30 bolt pattern is the same as s14 and s15 z32. 114.3?
Precision intercooler rated to 600HP Used **FOR SALE**
http://cgi.ebay.com/ebaymotors/ws/eB...%3AMESELX%3AIT
Slideways^Jordan is offline   Reply With Quote
Old 11-02-2009, 01:42 PM   #12
projectRDM
projectRDM's Avatar
It's a Nissan, isn't it? All 5lug Nissan vehicles use the same bolt pattern. I can't imagine someone thinking otherwise.
To the OP- There's a lot of this type stuff floating around, no real point in making one big thread since everyone will throw in useless posts or bad info. For example, the Z32 caliper info you have listed is wrong. ALL '90-'92 calipers are aluminum, '93-'96s are iron, NA or TT. Only the 1990 NA models are 26mm though, everything else is 30mm. Case in point, if you're going to bother making the list, you have to make certain it's dead on accurate or some kid next year is going to skim across it and cry about it being misleading.
FORMERLY R240NA
Old 11-02-2009, 08:15 PM   #13
jspec240
jspec240's Avatar
^^^ You are right about the calipers but I beg to differ about creating this thread, thanks for helping but just like you said there is a lot of this stuff "floating around" hence the creation of this thread. The whole point of creating a thread is so there is "less" searching to do.
If you would have read the whole post I did mention that if any of my info was incorrect to LMK which was done and corrected. so If that was the only thing wrong then I think I did a good thing by doing this.
DREW
Old 11-03-2009, 06:45 AM   #14
ZenkiKid
what are good oem tie rod combos for s13s?
Old 11-03-2009, 07:18 AM   #15
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
s14 inners are thicker and stronger. i'd just get some aftermarket ones
Slip Gypsies Blog
not sure if you realize this
Old 11-03-2009, 07:43 AM   #16
Z28ricer
Yes direct bolt on, I should add that I knocked off the ABS rings real quick with a hammer, that was the only other change.
Old 11-19-2009, 05:44 PM   #17
jspec240
jspec240's Avatar
Supra 440 injectors will fit with a resistor pack and top feed rail
DREW
Old 03-04-2010, 07:42 AM   #18
jspec240
jspec240's Avatar
Id like to start the thread back up again....
the bosch fogs that come on the older pathfinders and older altimas are sometimes listed as OEM ones for the s13. thats where you can get the switch and harness aswell.
DREW
Old 03-04-2010, 05:00 PM   #19
stinky_180
stinky_180's Avatar
Trader Rating: (26)
stinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud of
Feedback Score: 26 reviews
Send a message via AIM to stinky_180
i'll add something
90s maxima key ring light -> s13. the ones you see everyone selling on here. not direct bolt on; its seriously 2 wires.
SoCal RallyX Coverage and MTB Ride Reports
WheelsDirty
stinky_180 is offline   Reply With Quote
Old 03-04-2010, 05:19 PM   #20
I LUV MY S13
Trader Rating: (35)
Thanks
woah never saw this...but i wasnt being sarcastic NICO has tons of info in one spot
well your post wasnt any better sooo.....gtfo..?
-Jorge
Old 03-04-2010, 05:21 PM   #21
swayray
swayray's Avatar
swayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfection
That is correct but you'll need a 1mm spacer/washer to center the caliper w/ pads onto the rotor.... those spec-v rotors are very similar to the R33 GT-R w/ brembos only painted gold rather than black. i'll be having kits of these for under $1200 up soon....
http://www.thenismoshop.com
swayray is offline   Reply With Quote
Old 03-04-2010, 05:21 PM   #22
I LUV MY S13
Trader Rating: (35)
well this helped me out with replacin my bushings
Steering Rack Bushing Replacement – NICO Club
-Jorge
Old 03-04-2010, 05:41 PM   #23
jspec240
jspec240's Avatar
Originally Posted by stinky_180 View Post
i'll add something
Nice thats what Im about to do
Please keep me updated I may be interested
I knew this thread was worth bringing up... I know i luv my s13 said there is a thread on nico but rather than going back and forth we have our own now....
Im sure Nico has stuff that is not here so if you see something just copy and paste it here plse
DREW
Old 03-04-2010, 06:06 PM   #24
sr20detconv
sr20detconv is making a name for him/her selfsr20detconv is making a name for him/her selfsr20detconv is making a name for him/her self
I'm not so sure about that Z32 TT rear hub. I heard that the axles are bigger so the hole for the axle is also bigger. GTR Axles and diff are bigger and stronger and bolt-on(5bolts).
sr20detconv is offline   Reply With Quote
Old 03-04-2010, 06:25 PM   #25
jspec240
jspec240's Avatar
Yea they wont work on the 240s thats why everyone gets the N/A hubs which are a direct bolt on
DREW
Old 03-04-2010, 06:45 PM   #26
jspec240
jspec240's Avatar
I just found an archived post from duffman explaining Diff options
I'm going to fix/expand this:
Direct Fit:
91-93 240sx VLSD
89-90 JDM S13 VLSD
96-98 JDM S13 VLSD
JDM S14 and S15 VLSD (with S13 diff cover swapped on)
R33 Skyline (R34 as well?) VLSD (with S13 diff cover swapped on)
95-98 240sx VLSD (with S13 diff cover swapped on)
1/94+ J30 VLSD (with S13 Diff cover swapped on)
Fit with pre-1/94 J30 axles OR JDM S13 axles OR R32 Skyline axles OR 6 bolt vlsd output flanges OR shaved open diff output flanges:
90-96 NA Z32 VLSD
Pre 1/94 J30 VLSD
91 - 95 JDM S13 VLSD
JDM R32, A31 and others
Non VLSD oem options:
S15 torsen, 6spd turbo only: use S15 output shafts, late S14 VLSD might work, R230v might work with 3 out of 6 bolts lining up.
350Z/G35 torsen: supposedly R205 according to NISMO japan website. Unknown fitment in a 240sx.
DREW
Old 03-04-2010, 06:50 PM   #27
I LUV MY S13
Trader Rating: (35)
All you ever wanted to know about differentials – NICO Club
Differential swaps for the 240sx – NICO Club
Aftermarket Differential Install – NICO Club
-Jorge
Old 03-05-2010, 12:14 AM   #28
stinky_180
stinky_180's Avatar
Trader Rating: (26)
one more addition
the early 90s sentra ball joints are interchangeable as well. i used moog.
WheelsDirty
Old 03-05-2010, 11:13 PM   #29
jspeedm
jspeedm's Avatar
Trader Rating: (26)
jspeedm is on the path to ruinjspeedm is on the path to ruin
what year spec-v?
http://i404.photobucket.com/albums/pp128/jspeedm/Picture097.jpg
jspeedm is offline   Reply With Quote
Old 03-07-2010, 11:53 AM   #30
ZenkiKid
will this eliminate the need of trimming down the spindle?
