LOCATED IN REDLANDS ONTARIO RIVERSIDE COMPTON AND FULLERTON CA
LOCAL PREFERRED CAN SHIP SMALLER ITEMS AT BUYERS EXPENSE !!!!!FOR FASTEST RESPONCE PLEASE TEXT 909 283 9210!!!!!! S13 SR PARTS: -RHD front crossmember with ps line $60 ![]() -S13 redtop sr20 uncut engine harness SOLD ![]() -uncut lower harness $40 ![]() -turbo elbow with 02 sensor $30 ![]() -stock rad with fan shroud SOLD -clutch fan SOLD ![]() -ac compressor $40 -SMIC and piping $40 ![]() -Cxracing hot pipe $20 ![]() -isr turbo outlet gasket(new) $10 ![]() -Stock t25 turbo lines(missing oil bolt) $30 ![]() -new isr valve cover gasket $20 ![]() -stock intake manifold $30 ![]() KA PARTS: -SOHC 5 speed ecu #14 $25 ![]() -SOHC power steering line $10 ![]() -SOHC alum radiator SOLD ![]() -SOHC motor(no trans needs rebuild) $80 ![]() -SOHC fan $5 ![]() -DOHC SOLD ![]() S13 PARTS: -OEM LCA $15 ![]() -OEM inner and outer tie rods $10 ![]() -motor mount brackets $10 ![]() !!!!!FOR FASTEST RESPONCE PLEASE TEXT 909 283 9210!!!!!! Last edited by Martinem092396; 04-20-2016 at 06:13 PM.. Reason: Price drop |
| harness, s13, sohc, sr20, turbo |
