KA24DE - 370cc injectors, S14 MAF, CAI only. Will it run?
My KA24DE needs new injectors and I might get some 370cc injectors and an S14 throttle body. Already has an Injen CAI that isn't installed yet. Otherwise bone stock. Current injectors are causing it to run rich already. Will these changes be beneficial or will it run worse?
![]() Join Date: May 2008
definitely non-beneficial.. will run super rich, and eventually wash your cylinders in fuel.
secondly, an S14 maf and an S13 maf arent any better than each other, and are both tuned (on the ecu) for 270cc injectors.. and your injen intake, if its still new, return it, its not worth the 200$ you probably just spent on it. if you want more power, run premium gas and advance your timing a degree or two.. it will make about the same power
#4 | |
![]() Join Date: May 2009
You will run really rich and not very well without something to tune for the injectors.
