rb20 hesitation
So today I installed a mbc and played with the boost levels. When I got it set to ~10psi I accelerated at wot and got hesitation and a rapid backfire(ish) sound from the exhaust once full boost ~12psi was achieved. I then brought boost back down to 8-9psi and it ran just fine. Im guessing this is either a fuel or spark plug issue, correct me if im wrong.
stock smic t28 safc2 (untuned)
RBEAZY =D |
![]() Join Date: Feb 2009
Trader Rating: (47)
![]() Feedback Score: 47 reviews
Lower the spark plug gap to around .8
(My freinds rb20det did this SAME thing) If that does not fix it, then I would look into the coil packs.
![]() Join Date: Apr 2008
yep , i had this on my car exact same symptoms.
like the previous posts , check your plugs , play with your gap, i had to tinker with my gap a few times to get it bang on ... i wish i wrote it down somwhere cause i threw the plugs out. but even after that my car still hesitated a bit so i got new coil packs and smooth quick sailing from there |
