MY ingnition wont turn and my steering wheel is locked
I have 1990 s13 240sx and well here's the problem i i got into my car this morning and when i tried to turn the ignition to start the key it wouldn't turn and im a decently strong so i noticed i started bending the key cuz i was trying so hard. but before i even got in the car my key didnt work for the driver side either but it worked for my passenger and my trunk. So i figured maybe i need a new key that didnt work either :bash: help please :bash:
the steering wheel locked, any in turn locked the ignition barrel
just wiggle both the key in the ignition and the steering from side to side at the same time, it should unlock
445whp stock engine, epic street/track BNR32 |
I had this happen to my car
Did you convert you car from auto? If so the auto has a park lock. this must be engaged. Check in the center console for a steel cable. If it is there cut the cable. This auto lock is the one that you have to hold to brake to put the car in gear. Hope this helps. If you did not convert it then I am not sure why.
![]() Join Date: Mar 2009
haven't you guys ever stolen a car...
Take the column covers off, unbolt the key cylinder from the steering column, wheel is now unlocked. Take the key cylinder apart and unplug the connector on the key-side, jump the connector with a jumper wire. Then turn the other side of the cylinder with the key or anything, Bam drive away. |
#13 | |
I have no idea why, but i just almost died laughing
IN THE MARKET FOR A CLEAN s13 SHELL, OR A CLEAN DC TEG SHELL!! |
